L0N3S0MER4NG3R Posted July 8, 2017 Share Posted July 8, 2017 (edited) RB25DET NEO stalls once its warm Hey guys my RB25det R34 has recently developed a problem where the car decides to stall once it is warm, this tends to be when i am at traffic lights stopped or crawling pace, has also happened when ive been in the lower rev range but i have found that so long as i keep the revs above 3k rpm it doesnt happen. i have checked coolant temp resistances and they all look about right when cold its 3250 ohms and warm 230 ohms. The wires to the o2 sensor have been cut for as long as ive owned the car and worked fine for 2 months then started this problem so key points, -Dies once warm -Coolant temp sensor looks good -seems to be fine with higher revs car specs: STOCK RB25DET NEO with fmic, turbosmart bov to atmosphere, link g4 ecu Thanks in advance Edited July 8, 2017 by L0N3S0MER4NG3R Link to comment https://www.sau.com.au/forums/topic/471179-rb25det-neo-stalls-once-its-warm/ Share on other sites More sharing options...
GeeDog Posted July 8, 2017 Share Posted July 8, 2017 3 minutes ago, L0N3S0MER4NG3R said: Coolant temp sensor looks good Which coolant temp sensor are you testing? The 2 wire one (on an R33 RB25 - assume Neo is the same) is the one the ECU reads. Link to comment https://www.sau.com.au/forums/topic/471179-rb25det-neo-stalls-once-its-warm/#findComment-7839121 Share on other sites More sharing options...
L0N3S0MER4NG3R Posted July 8, 2017 Author Share Posted July 8, 2017 18 minutes ago, GeeDog said: Which coolant temp sensor are you testing? The 2 wire one (on an R33 RB25 - assume Neo is the same) is the one the ECU reads. The ecu sensor (two wire) Link to comment https://www.sau.com.au/forums/topic/471179-rb25det-neo-stalls-once-its-warm/#findComment-7839126 Share on other sites More sharing options...
L0N3S0MER4NG3R Posted July 8, 2017 Author Share Posted July 8, 2017 Sorry forgot to add it won't start for awhile usually after this as if it s to cool down. It's not everytime I stop just at random once warm Link to comment https://www.sau.com.au/forums/topic/471179-rb25det-neo-stalls-once-its-warm/#findComment-7839130 Share on other sites More sharing options...
WHITEBEAST Posted July 8, 2017 Share Posted July 8, 2017 If you are using the ECU that come with engine. It might be throwing a code, if you can plug it into a reader. You could also bypass the sensor with a specific range resistor to give you what ohms you want. Good luck. Link to comment https://www.sau.com.au/forums/topic/471179-rb25det-neo-stalls-once-its-warm/#findComment-7839136 Share on other sites More sharing options...
L0N3S0MER4NG3R Posted July 8, 2017 Author Share Posted July 8, 2017 1 minute ago, WHITEBEAST said: If you are using the ECU that come with engine. It might be throwing a code, if you can plug it into a reader. You could also bypass the sensor with a specific range resistor to give you what ohms you want. Good luck. I am running a link g4 ecu, but don't have a cable so can't see what's happening with it at the moment. Don't need to bypass the coolant sensor as I believe it's working fine, I just logged what happend around then Link to comment https://www.sau.com.au/forums/topic/471179-rb25det-neo-stalls-once-its-warm/#findComment-7839137 Share on other sites More sharing options...
Binarydata Posted July 8, 2017 Share Posted July 8, 2017 Check the CAS. I was having the same issue. If you pull it off (after marking where it was) it should spin easily and freely. Swap it out for another one if you can. Link to comment https://www.sau.com.au/forums/topic/471179-rb25det-neo-stalls-once-its-warm/#findComment-7839140 Share on other sites More sharing options...
L0N3S0MER4NG3R Posted July 8, 2017 Author Share Posted July 8, 2017 Just now, Binarydata said: Check the CAS. I was having the same issue. If you pull it off (after marking where it was) it should spin easily and freely. Swap it out for another one if you can. Hi, have brought one this week but wanted to check everything simple first, is there anything I need to do or can o just mark where it is pull it off and throw a new one in the same way Link to comment https://www.sau.com.au/forums/topic/471179-rb25det-neo-stalls-once-its-warm/#findComment-7839141 Share on other sites More sharing options...
Binarydata Posted July 8, 2017 Share Posted July 8, 2017 I just marked where it was, put the new one on. Checked that the CAS was the issue then set the timing with a light. Link to comment https://www.sau.com.au/forums/topic/471179-rb25det-neo-stalls-once-its-warm/#findComment-7839142 Share on other sites More sharing options...
L0N3S0MER4NG3R Posted July 8, 2017 Author Share Posted July 8, 2017 1 hour ago, Binarydata said: I just marked where it was, put the new one on. Checked that the CAS was the issue then set the timing with a light. Will try that tomorrow and let you know how it goes Link to comment https://www.sau.com.au/forums/topic/471179-rb25det-neo-stalls-once-its-warm/#findComment-7839151 Share on other sites More sharing options...
WHITEBEAST Posted July 8, 2017 Share Posted July 8, 2017 (edited) I had an issue with a V8 CAS, it sounds the same. The contacts stuff up in them. If you tip cold water on CAS at front of the engine. Does it start sooner? Edited July 8, 2017 by WHITEBEAST Link to comment https://www.sau.com.au/forums/topic/471179-rb25det-neo-stalls-once-its-warm/#findComment-7839162 Share on other sites More sharing options...
L0N3S0MER4NG3R Posted September 21, 2017 Author Share Posted September 21, 2017 (edited) so ended up borrowing my mates link g4 cable and turns out i have a link g4+, i logged a drive and when it died the map sensor went nuts, wiggled the wires and away it went again. just cut the wiring out and redo it? screenshots from moment it died (it was running normal in the first photo) Log 2017-09-21 12;55;58 pm.llg Edited September 21, 2017 by L0N3S0MER4NG3R more info Link to comment https://www.sau.com.au/forums/topic/471179-rb25det-neo-stalls-once-its-warm/#findComment-7850825 Share on other sites More sharing options...
