R33 Gtst - AC noises every ~30 secs
Hello guys
When I turn the AC on, every ~30 seconds I can hear a sound from the outside, Im not sure how its exactly like, but Id describe it with "fizzle" combined with a short engine stuttering like you know it from broken coils.
Id also say, the intensity depends on the speed you drive; it doesnt seem to appear while standing with the and engines obviously running on the common 700/750 rpms
We recently did the whole timing belt change, could this have something to do with it?
Thanks a lot
https://www.sau.com.au/forums/topic/471185-r33-gtst-ac-noises-every-~30-secs/
If its on the 'outside' then it can only really be the compressor or a leaking line. Perhaps something wrong with the A/C Fan on the condensor but doesn't sound consistant with what you have described.
Sounds like A/C Compressor if it changes with RPM. Could be an issue with a bearing of the clutch, or might be a belt issue also
Ok ok so what would be my next step? Tighten the belt wouldnt change a change would it? I was thinking about a leak too therefor I stopped in a bus lot, but I have not heard anything.
Like said, not working without driving - I do believe its worst when 4th gear and about 3500rpms - its almost like an aftermarket bov man.... What could that cause other than a leak which it is obviously not the case
Hm, what I can say for sure, it only appears when I turn AC on; with the right rpms it comes straight with the button pressing and then like I described - every 25/30 secs.
I had the feeling, that it almost sounds like something pulling hard, but thats just one of those "maybe possibilities thoughts if the mainthought is wrong" ^^ And the main thinking is that air pop sound.
I dont know exactly when it started, but we changed the whole timing belt stuff 3 weeks ago and everything was fine before - but would that have something to do with this issue?
^^ Like said, 3rd 4th gear hard to film and understand anything; we tried to get the sound but you mostly get wind screaming obviously; Ill give it another try in the weekend so you might check out for yourself
I have this issue as well....its like a small sneeze.  I have it on my Gtst AND my ford courier both.  Had both vehicles to the aircon specialist here and he laughed but after taking the courier for a drive came back scratching his head.  All gas pressures are fine, the condenser and all other parts are fine, everything tested perfect.  He said drive it till it fails
Well I have been driving both vehicles now for over 2 years and except for the sneeze...nothing...everything is working perfectly.
More worried for the courier cos its a single belt, but so far so good.
I am not sure if the engine stutters or not, I sometimes thing it does, and other times think it doesn't.  I think its got something to do with the condenser cutting in and out and loading the engine - as opposed to a misfire.
Well ye I could live with it IF it would be normal like everybody says - but as I mentioned it just came up after timing belt stuff and I dont wanna get used to something that is so obviously "wrong". I tried to record it but its hard cause of the wind or murphys law - everytime we try to record - nothing. Trying just to know - major sound ^^
Try this one pls, its one of the quieter appearances but you can hear it in the end.
its an opus file - just use VLC
2017-07-23-AUDIO-00007494 (1).opus
    • Also sorry to hear this @DanielStone - I remember @SmoothLine well, he was around for a very long time and was one of the original members of this site.  God Speed Matt. Thoughts with his family and friends.
    • Nice car! Looking at your GTS; makes me wonder why I bought a GTS-t... Everything has been changed anyway. I should have just started with a non turbo model.
    • Rear doors central locking wiring removed and cleaned. See the first 8sec video of when it’s filled with river silt. its a snip of what I’m up against. front and rear doors complete now. Maybe another day removing carpet and bits and pieces. Then the re assembly begins. 🤙 att.DqweJqhY5MZiZYQDVMhn3LtvdD1RBZ7TBG4f2s7W1zM.mp4 att.lFuN22MZEowqCbFAXoDw009r2gHL76ChMVfxMfBX-uk.mp4
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
