Aeroflow silver braided fuel lines front -8 to back -6 with aeroflow surge tank with two 044s $850
R34 gtr abs unit no leaks brake master and lines included $450
R32 Gtr plenum with large single hale racing throttle body ,deleted itbs with nitto gaskets and alloy intercooler pipes for both sides which suit this plenum $350
R32 gtr 3 1/4 or 1/2 inch exhaust system $350
R32 gtr fenix alloy radiator with thermo fans $300
R34 gtr crank angle sensor $300
R32 gtr abs unit no leaks brake master ,brake lines included $250
R34 gtr braided brake lines $200
R32 gtr crank angle sensor $150
R32 gtr strut brace $100
R32 gtr alternator no front pulley $100
R34 gtr hicas rack $100
R34 gtr factory map sensor $100
Rb26 bottom timing cover $50
Rb26 dipstick $50
IMG_1723.jpgIMG_1725.jpgIMG_1728.jpgIMG_1730.jpgIMG_1731.jpgIMG_1732.jpgIMG_1734.jpgIMG_1726.jpgIMG_1724.jpgIMG_1722.jpgIMG_1741.jpgIMG_1736.jpg
https://www.sau.com.au/forums/topic/471214-gtr-parts/
  • 4 weeks later...
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
    • So unsafe would you say now?   little bit of has come off, guess road salt is a nightmare for Japanese car. Mx5 here have a well known issue or rotting
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
