Adelaide - group buy for Evo Brembo brake conversion kit
Very similar to timmy's thread here:
Alpha Omega dont do any more discount, however we will be saving on combined postage for Adelaide only.  I have found another supplier for the fronts, they will be around $200 and $100 for the brake lines.  Obviously the more ppl we get the cheaper it will be.  The rears will need to be through alpha omega.
We can get the rotors about $100 each cheaper.  If you can get better prices on the rotors please let me know.
Runs from today until Tuesday next week 19th July.  Ive spoken to a few of you on other forums fb pages etc.
You run evo 6-9 calipers - they are all the same and an evo 10 350mm rotor and 350mm rotor from 370z.
You can purchase calipers for $850 from alpha or look around for cheaper
DBA T3 4000, slotted rotors. price plus postage
$381 fronts and $326
ADELAIDE ONLY
om
Also can get front rotors $245 inc post, less for more people
RDA Slotted and Dimpled Rotors
  • Front Rotors (2 rotors)
  • Diameter - 350mm
  • Original Height - 44mm
  • Original Thickness - 32mm
  • Min. Thickness ie. Relpacement - 30mm
  • Centre Hole - 69
  • Bolt Holes - 5
Discs are genuine RDA items and include the RDA 12 month, 20,000km warranty.
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
    • A seat I find stupidly comfortable to sit in is the one in a friend's Merc Race Car. It even has the huge wings that wrap around your head. Best ever. Only issue is climbing through his scaffolding he put up in the doorway of the car... Ha ha ha. I sat in that seat for a couple of hours doing wiring. Another stupid comfortable seat I find, especially if my back is aching, is my OMP fixed back bucket seat too. I'll just sit on it when I'm exhausted in the garage sometimes to relax!
    • I just got off the phone with Dean from Vosta in Brisbane. They are the ones that do the replica seats and they have a shop full of seats for my to try out. Lovely guy.  I haven't decided whether to go genuine or replicas, I'm leaning towards Genuine at this point but who knows.  Also thinking the STRADIAs are the way to go VS the GIAS since they have a lower hip edge and would be easier to get into. Don't really like the idea of arm rests on the models to the right of this diagram either, maybe they can be removed?
    • From my own first hand experience, keeping power for a fun Street able skyline down at a responsive low 200 wheel KW, is the best. It makes it super drive able through the twisties, you're not just smashing mass wheel spin, or only able to open the throttle for a split second before being at absurd speeds. That said, plenty of people like being morons at more than double the speed limit on public roads and hence are happy with 600whp and seeing 200kmh fly up frequently and fast. Also, at that low 200, a GTR can still do a decent quarter mile, and with a bit of fancy  clutch work (foot, not the parts) can still beat many many cars in a traffic light gp, even in the wet.
