VQ25DET flywheel bolt torque? Please help
Hi all been reading for last few years site is awesome resource although i'm having trouble finding a workshop manual for a m35 stagea or a v35.
Attempting to convert a 4 door v35 to vq25det 2wd with 350z z33 gearbox. Have sorted the clearance issues and removed the front diff from motor and starter/ gearbox which with some fab work will work and bolt into the stock location for the vq25 and hit the manual flywheel spot on.
been unable to find flywheel torque bolt specs for the vq25det which is holding up putting the clutch on and testing tailshaft length.
Thanks all
Edited by roadhazzard1
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
