Brendons M35 build
Thought I'd create a mini build thread on my progress with my first foray into Nissan wagon life and also a place to ask questions/path to follow.
I bought the car with f**ked coil packs so I picked it up cheap off some Indian guy. Put a new set of coil packs in and all was sweet for the next 6 months . . .
https://imageshack.com/i/pnV0vOWcj
https://imageshack.com/i/pltD8QHij
https://imageshack.com/i/popQVxMsj
I noticed an oil leak from the passenger side that was slowly getting worse and traced it back to the oil feed line. Ah well no biggy, just an easy fix or so I thought! Having not worked on a VQ before, it wasn't until later on I discovered you can't get the line off without pulling the whole turbo :down: Since the car wasn't far off 200k and the turbo had begun the Dyson whine song, I frantically searched for a new turbo. Scotty to the rescue with a Billet Intense he had spare that got to me in 4 days.
In the mean time while the car was off the road I set about fabbing up a 3" bellmouth dump pipe.
Then followed it up with a 3"-2.5" intake pipe. (Still need to weld on BOV return bung)
And this weekend just gone I fabbed up a 3" catless exhaust system to finish it all off. I picked up 7psi of boost without touching a thing, so it's stuck on 21psi with standard injectors and pump. I've hit up Christian to see if it's possible to run the car safely at this level on 98 with his flash tune, otherwise I will probably put a hi-flow cat in to drop the boost a little.
I've got a few other things in the works but all in due time!:10_wink:
Edited by Sack87
Pics not working
  • Like 8
https://www.sau.com.au/forums/topic/471232-brendons-m35-build/
Productive day trying out my my new pipe bender. Made up a rear subframe brace to help reduce some flex because the factory welds back there horrid. :2_grimacing:
I plan on making a few more of these up, so watch this space if you're interested in one:1311_thumbsup_tone2:
  • Like 5
You can buy a brand new one from Nissan for around $100 but your looks solid and nice welding.
Replaced the headlight globes last weekend with some LED Nighteye ones off eBay.
Fixed the dodgy wiring job obviously done by the compliance shop and also fixed the issue with the passenger side globe constantly dropping out. The H1 globes earth through the clip into the light body but the clip had been bent and contact was poor. The LED globes have earth through the harness, so crimped on some plugs and walla!
They just fit in behind the cover luckily and beam spread is awesome. High beams are like having spotlights fitted.
  • 5 weeks later...
  • 3 weeks later...
Made the mounts for the FMIC. They just touch the grill mounting tabs on the front bumper by about 3mm so I'll have to dremel a little bit off but it won't be noticeable.
Also did the hot side piping and some of the cold side but forgot to grab a 3" 45 degree bend. I plan on making it 3" to the throttle body eventually as I need to run a 3" to 2.5" 45 degree reducer currently.
  • Like 3
  • 5 weeks later...
Made up the rear subframe front brace to finish off the trio. I'll make a few more up as usual and will look into gearbox bracing next.
Also got around to fabbing up the 3" IC piping that goes to the throttle body so it's full 3" from the FMIC. Just need to finish tidying up around where I silver soldered the nipples in and the BOV flange needs facing.
  • Like 6
Finished off fitting the FMIC and wrapped the 3" throttle piping in heat reflective tape.
Next on the list is to make up a few little brackets to relocate the sensor and solenoid and clean up the hosing.
  • Like 3
  • 5 weeks later...
The plastic under body engine guard was looking pretty poor so I decided to make a new one up out some ali sheet. I made up a template and cut out a simplified version of the factory one. But what do you do when you don't have a sheet metal bender?...
You make your own one; and it works f**king mint :happy: It's a heavy duty sucker that will do up to 3mm sheet and stores away nicely with removable handles. I still need to add some vertical supports to the angle that bolts down on the sheet and drill some holes to mount it to the bench instead of using clamps.
So with that side project made, I bent up the sheet and you end up with a nice shiny undertray.
I'm also working on something else too as you can see but it's still in the "refinement" stage.:1311_thumbsup_tone2:
  • Like 3
Made up a smaller reo bar so I can fit a FMIC in without having to change condenser fan and also make more room to fit in a trans cooler.
Hey, any chance I can get the dimensions of that front bar? The length. I was considering doing the same type of thing to mine because of my fmic!
  • 4 weeks later...
On 29/12/2017 at 10:58 AM, jordanricketts3 said:
Just the length of the bar itself and how far in you did the bends
Sorry for taking so long to get back to you.
Bends are 130mm from the ends and total bar length is 690. Just make sure you slot the holes in the mounting plates otherwise it's a PITA to get on.
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
