Brendons M35 build
Thought I'd create a mini build thread on my progress with my first foray into Nissan wagon life and also a place to ask questions/path to follow.
I bought the car with f**ked coil packs so I picked it up cheap off some Indian guy. Put a new set of coil packs in and all was sweet for the next 6 months . . .
https://imageshack.com/i/pnV0vOWcj
https://imageshack.com/i/pltD8QHij
https://imageshack.com/i/popQVxMsj
I noticed an oil leak from the passenger side that was slowly getting worse and traced it back to the oil feed line. Ah well no biggy, just an easy fix or so I thought! Having not worked on a VQ before, it wasn't until later on I discovered you can't get the line off without pulling the whole turbo :down: Since the car wasn't far off 200k and the turbo had begun the Dyson whine song, I frantically searched for a new turbo. Scotty to the rescue with a Billet Intense he had spare that got to me in 4 days.
In the mean time while the car was off the road I set about fabbing up a 3" bellmouth dump pipe.
Then followed it up with a 3"-2.5" intake pipe. (Still need to weld on BOV return bung)
And this weekend just gone I fabbed up a 3" catless exhaust system to finish it all off. I picked up 7psi of boost without touching a thing, so it's stuck on 21psi with standard injectors and pump. I've hit up Christian to see if it's possible to run the car safely at this level on 98 with his flash tune, otherwise I will probably put a hi-flow cat in to drop the boost a little.
I've got a few other things in the works but all in due time!:10_wink:
Edited by Sack87
Pics not working
  • Like 8
https://www.sau.com.au/forums/topic/471232-brendons-m35-build/
Productive day trying out my my new pipe bender. Made up a rear subframe brace to help reduce some flex because the factory welds back there horrid. :2_grimacing:
I plan on making a few more of these up, so watch this space if you're interested in one:1311_thumbsup_tone2:
  • Like 5
You can buy a brand new one from Nissan for around $100 but your looks solid and nice welding.
Replaced the headlight globes last weekend with some LED Nighteye ones off eBay.
Fixed the dodgy wiring job obviously done by the compliance shop and also fixed the issue with the passenger side globe constantly dropping out. The H1 globes earth through the clip into the light body but the clip had been bent and contact was poor. The LED globes have earth through the harness, so crimped on some plugs and walla!
They just fit in behind the cover luckily and beam spread is awesome. High beams are like having spotlights fitted.
  • 5 weeks later...
  • 3 weeks later...
Made the mounts for the FMIC. They just touch the grill mounting tabs on the front bumper by about 3mm so I'll have to dremel a little bit off but it won't be noticeable.
Also did the hot side piping and some of the cold side but forgot to grab a 3" 45 degree bend. I plan on making it 3" to the throttle body eventually as I need to run a 3" to 2.5" 45 degree reducer currently.
  • Like 3
  • 5 weeks later...
Made up the rear subframe front brace to finish off the trio. I'll make a few more up as usual and will look into gearbox bracing next.
Also got around to fabbing up the 3" IC piping that goes to the throttle body so it's full 3" from the FMIC. Just need to finish tidying up around where I silver soldered the nipples in and the BOV flange needs facing.
  • Like 6
Finished off fitting the FMIC and wrapped the 3" throttle piping in heat reflective tape.
Next on the list is to make up a few little brackets to relocate the sensor and solenoid and clean up the hosing.
  • Like 3
  • 5 weeks later...
The plastic under body engine guard was looking pretty poor so I decided to make a new one up out some ali sheet. I made up a template and cut out a simplified version of the factory one. But what do you do when you don't have a sheet metal bender?...
You make your own one; and it works f**king mint :happy: It's a heavy duty sucker that will do up to 3mm sheet and stores away nicely with removable handles. I still need to add some vertical supports to the angle that bolts down on the sheet and drill some holes to mount it to the bench instead of using clamps.
So with that side project made, I bent up the sheet and you end up with a nice shiny undertray.
I'm also working on something else too as you can see but it's still in the "refinement" stage.:1311_thumbsup_tone2:
  • Like 3
Made up a smaller reo bar so I can fit a FMIC in without having to change condenser fan and also make more room to fit in a trans cooler.
Hey, any chance I can get the dimensions of that front bar? The length. I was considering doing the same type of thing to mine because of my fmic!
  • 4 weeks later...
On 29/12/2017 at 10:58 AM, jordanricketts3 said:
Just the length of the bar itself and how far in you did the bends
Sorry for taking so long to get back to you.
Bends are 130mm from the ends and total bar length is 690. Just make sure you slot the holes in the mounting plates otherwise it's a PITA to get on.
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
    • For most rotisseries, as Duncan has mentioned, you really don't want a full car on it, you want a stripped shell. And imagine how many more weeks THAT is going to add to working on the car...
