Built both heads up today. Only put Supertech valve stem seals in and OEM for the rest as there are no aftermarket springs or valves available for these.
I now have a 4 week delay on rod bearings from Japan so that's pretty much all I can do until the new year.
  • Like 2
Not much of an update but painted N1 vents and parking stick thingo.
Also cut out the middle of the bumper to suit the new plates and gain more airflow as these like to run hot.
  • Like 1
Don't like how big and bulky the airbox is and the stupid sound suppression part that just collects sand!
Started off like this
Chopped it in half and then I was left with this nice flat surface to adhere the new mounting section to.
Also noticed that the round section actually sits outside the chassis rail in the wheel arch, so incorporated a cold air intake port into the new piece.
  • Like 2
Finished re-sleeving the whole harness tonight finally. What a mission but I think the outcome will pay off with a much neater engine bay. All I need to do is buy some larger clear heat shrink so I can branch the connectors off to where they need to go.
I won't tee it all off though until its on the engine as I might be able to re route some it to further neaten it up.
Not Rywire or Chase bays spec but gives it that little extra professionalism.
Got the turbo back from getting rebuilt by MTQ as well. Shaft and cartridge journals were scored, some bent turbine fins and a small crack in the rear housing.
The rod bearings are going to be here until January now, so when I get back from Holidays it's go, go, go!
Edited by Sack87
  • Like 2
  • 3 weeks later...
I got the engine to a stage where I could bolt the gearbox back on and drop it on the subframe. I can easily roll it all out for the remaining work to do on it for ease of access.
Had more delays in timing chains not being in stock locally and having to get them from Japan again and they won't be here until next weekend. Have some small bits coming from over East too which were supposed to be here by Friday but not coming until next Thursday, otherwise I would have bolted the whole lot back in the car.
  • Like 2
Engine harness is all but done. A few little brackets to be made and two more connectors needed. It's 10x neater than what it was.
Injector harness is almost fully tucked.
Degreased the engine bay as I'm 95% ready to bolt the engine up to the body. Someone else has already been in here before me.
  • Like 1
Can you tell us what you had done to the turbo? Looks like a bigger compressor wheel... steel/inconel turbine? Cost? Expected power? So many questions... :)
Looking good by the way!
Edited by andynogo
It's a Billet Intense RS I bought from Scotty a few years ago. You'll find heaps of info on it in the turbo upgrade thread, but good for 500hp he says.
  • Like 1
Very good- should make some decent power!
On 1/28/2019 at 7:53 PM, Akshunhiro said:
Looks like someone had the joy of swapping out the turbo!
Yep. Everything has silicone on it to seal it up, including water hoses onto pipes. I bought a dud...
Got it bolted back this afternoon after doing heaps of little things around the engine that are hard to get to when it's bolted in.
Still heaps of fiddly little shit to go though
  • Like 5
  • 3 weeks later...
    • It will sound tragic and you wished you didn't have 1x exhaust per turbo. There's a reason why most S55 owners change to a single mid pipe.
    • Echo the comments about the well preserved condition it's in. It has the aero bumper too for extra points. Nice car, and please keep it like that! 🙂
    • 1. There are no real performance benefits. It sounds different, and as the pipes are not as large diameter you can claw back some undercar clearance or run lower (if that's your thing). 2. Twin pipes, offering exactly the same cross sectional area as a single pipe** will have higher pressure drop - so will not flow as well. That's because there is more surface area of wall per cross sectional pipe area, hence more frictional losses. ** But of course, it is almost impossible to get 2 pipes that are exactly the same XS area as a given typical single pipe. eg, 2x2" is not the same as 1x 3", although it is close. If the 2x pipes add up to less XS area than the single - it will just be flat out worse. If the 2x pipes add up to a bit more than the single, then it might come out as a wash. If the 2x pipes are substantially more XS area than the single, then it will probably flow a little better. 3. No. Why would there be? What have cats got to do with boost creep?*** ***But for f**ks' sake, please run a cat. 4. If you want.
    • UPDATE: was able to have the bracket repaired and base repaired, seat is like new now ;)
    • I was going to say it looks right out of Gran Turismo photoshoot when you just buy the car. (in a good way)
