On 7/12/2017 at 10:32 AM, Sack87 said:
 I picked up 7psi of boost without touching a thing, so it's stuck on 21psi with standard injectors and pump. I've hit up Christian to see if it's possible to run the car safely at this level on 98 with his flash tune, otherwise I will probably put a hi-flow cat in to drop the boost a little.
LOL LOL LOL what would Christian know!!! and why would you trust his flash tune meant for a different motor HAHAHA
Firstly your not making any power over 16PSI (on a stock turbo) as the turbo cant flow that much air your just producing extra heat.
Go see a real tuner and put the car on a dyno before you punch Piston #6 out of the block like the rest of you new age Stagea owners
and put a 100cell cat on the thing FFS
  • Like 1
And you know everything I assume, including how to hack and tune a factory Ecu?
Firstly I'm running a Billet Intense RS Turbo and secondly it's safe on 19psi as my AFR doesn't go above. 93v at WOT.
And it's "you're" by the way.
  • Like 5
  • Haha 2
  • 1 month later...
3 hours ago, Ben C34 said:
Does that actually achieve anything? Or just theoretical?
No idea haha, most probably not but it cost me nothing to make.
The more the better theoretically. I wanted to make up one that picks up several points but theres just no room under the car.
  • Like 1
  • 5 weeks later...
Interested in an Intense turbo and am running Itsrom ECU atm. I am getting just over 17psi atm (according to an autobarn gauge) using Scottys dump and front pipe and a Nur tailpipe. The car is vastly improved by Itsrom and has standard intake currently. Was thinking about Scottys Intake or an AMP one and wondered how you got on with yours? People talk about fuel cut and I figure the Intense and an intake is going to get there. You did not mention this so I was wondering what you did ... Thanks
I've had no issues at all with my setup and haven''t had it fuel cut once.
  • 2 months later...
17 hours ago, Skylinefreak1 said:
That's some fancy fab work mate! Looks great! Anything else done recently?
Thanks mate.
I recently bought a TIG welder so I can do aluminium work but mostly to fix up my rear subframe as it's cracked.
I've got a few things in the works including building a new engine soon as the current one is cactus. Just trying to keep this one going until the other engine is ready :654_bomb:
So this is what I have in the works currently and I just tick along with them.
Designed and 3D printed a pistol grip style shifter. Unlike the generic ones you can buy, this one slides on like the factory one and uses the circlip to hold it on snug. The cover at the base fits like a glove but I was limited to how much radius I could put on the shifter to match the cover.
I finalised the design of my 3D printed catch can so just waiting on fittings to come so I can hook it all up and test out how well the ABS holds up to heat and fumes. The fitting by itself replaces the factory PCV and I had to get that from the states.
The catch can is fully baffled inside and just requires some steel wool and the other baffle to be fitted.The top had to be removable as you can't print a baffle inside and object and know if it has printed properly.
If the 3D printed one doesn't work, then I have all the individual pieces cut up ready to be fabbed up. This will be my first TIG welding project since buying one as I have only used MIG.
To get the fumes to the catch can location I made up a steel hard line that goes from the passenger cam cover, along the fuel rail and follows behind the timing cover.
Knocked up a cooling mod but mine uses an SOS fitting as the bleed point. If your're familiar with Caterpillar mining equipment then you'll know why I chose this!
To go along with that I bought a generic breather tank setup that will most likely go above the passenger cam cover. This is the highest point in the engine bay, has the most room and is easier to tap into the bottom rad hose.
After doing the rear rotors I saw that the subframe was cracked on both sides pretty badly, also another reason why I bought the TIG welder. I made up a cardboard template and the aluminium I transfer that to will get welded in for more strength.
And most recently I had a knock senor code throw up after handling the harness. Found this just hanging out in the valley.
Plan is to buy another harness and re plug the whole thing as most of the connectors are breaking apart or already broken.
  • Like 2
21 hours ago, myothercarsa2cv said:
Amazing work Brendon as ever! Some tasty parts there that I’m sure a few of us would be interested in if you wanted to make some more... ;)
I plan on making some of this to sell in the future but I want to run it on my car for a bit to see what works and what doesn't.
I may make up a different catch can setup that uses easier hose routing but it means you can't run the turtle shell.
Edited by Sack87
I got my hose fittings yesterday and fitted the catch can. I'm not 100% sure I like this location now as the lines are just clearing the bonnet as they are sitting on top of the overflow bottle.
PCV delete and hose fitting just have enough room with a 3" intake
I will need to beef up the lid bracket and slightly adjust it as it snapped when moving it around. You can also just see the breather hidden away under the guard. I will move this too as it fouls on the guard liner.
  • Like 2
Really neat and nicely packaged. Shame there’s not a lot of room in our engine bays, would make life a little easier!
Is the PCV delete worthwhile? I’d have thought the breathing would be better with it in place?
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
