Built both heads up today. Only put Supertech valve stem seals in and OEM for the rest as there are no aftermarket springs or valves available for these.
I now have a 4 week delay on rod bearings from Japan so that's pretty much all I can do until the new year.
  • Like 2
Not much of an update but painted N1 vents and parking stick thingo.
Also cut out the middle of the bumper to suit the new plates and gain more airflow as these like to run hot.
  • Like 1
Don't like how big and bulky the airbox is and the stupid sound suppression part that just collects sand!
Started off like this
Chopped it in half and then I was left with this nice flat surface to adhere the new mounting section to.
Also noticed that the round section actually sits outside the chassis rail in the wheel arch, so incorporated a cold air intake port into the new piece.
  • Like 2
Finished re-sleeving the whole harness tonight finally. What a mission but I think the outcome will pay off with a much neater engine bay. All I need to do is buy some larger clear heat shrink so I can branch the connectors off to where they need to go.
I won't tee it all off though until its on the engine as I might be able to re route some it to further neaten it up.
Not Rywire or Chase bays spec but gives it that little extra professionalism.
Got the turbo back from getting rebuilt by MTQ as well. Shaft and cartridge journals were scored, some bent turbine fins and a small crack in the rear housing.
The rod bearings are going to be here until January now, so when I get back from Holidays it's go, go, go!
Edited by Sack87
  • Like 2
  • 3 weeks later...
I got the engine to a stage where I could bolt the gearbox back on and drop it on the subframe. I can easily roll it all out for the remaining work to do on it for ease of access.
Had more delays in timing chains not being in stock locally and having to get them from Japan again and they won't be here until next weekend. Have some small bits coming from over East too which were supposed to be here by Friday but not coming until next Thursday, otherwise I would have bolted the whole lot back in the car.
  • Like 2
Engine harness is all but done. A few little brackets to be made and two more connectors needed. It's 10x neater than what it was.
Injector harness is almost fully tucked.
Degreased the engine bay as I'm 95% ready to bolt the engine up to the body. Someone else has already been in here before me.
  • Like 1
Can you tell us what you had done to the turbo? Looks like a bigger compressor wheel... steel/inconel turbine? Cost? Expected power? So many questions... :)
Looking good by the way!
Edited by andynogo
It's a Billet Intense RS I bought from Scotty a few years ago. You'll find heaps of info on it in the turbo upgrade thread, but good for 500hp he says.
  • Like 1
Very good- should make some decent power!
On 1/28/2019 at 7:53 PM, Akshunhiro said:
Looks like someone had the joy of swapping out the turbo!
Yep. Everything has silicone on it to seal it up, including water hoses onto pipes. I bought a dud...
Got it bolted back this afternoon after doing heaps of little things around the engine that are hard to get to when it's bolted in.
Still heaps of fiddly little shit to go though
  • Like 5
  • 3 weeks later...
    • Nah, just take the other one off too
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
