Got the airbox mod 3d printed and temporarily screwed it on as it's only minimum infill for trial.
Fits perfectly and the cold air inlet sits just outside the main frame rail.
Also modified the power steering reservoir by making my own bracket as it didn't clear the bonnet when closed in the stock one.
  • Like 2
So I got it going today but have a few issues.
Turbo coolant hose has split, kinda knew it would.
Power steering keeps leaking at the pump so just going to use the old setup
Crank position sensor is throwing a code so it could be f**ked
It keeps overheating. Doesn't matter what I do, i can't get it to not overheat.
Edited by Sack87
1 hour ago, TukeH said:
Whats that strange cliking sound is?
When the water hits the power steering belt it makes that weird noise. You can see the water spitting out of the radiator neck. Took me a few minutes to figure out what it was haha
Edited by Sack87
17 hours ago, Akshunhiro said:
Nice work with the airbox. Would you mind sharing the STL? Or, can I buy one off you? My 3D printer is still waiting to be assembled haha.
Let me test it out first to see how it goes with the heat, then I'll look at selling the STL file if it doesn't melt haha
It only just fit on the Makerbot Replicator bed so yours needs to be the same size.
So I got the coolant bled to a point where I could drive it without overheating and run the engine in for 100km.
Installed a GFB G Force 3 boost controller on a little bracket I made up that fits in the vent. I can monitor AFR later on when I put another sensor in and protect the engine incase it leans out. So many cool features with this unit.
Also had a mate dip the grill in carbon fibre. Came out really good and matches nicely with the ARX kit.
  • Like 4
  • 3 weeks later...
I haven't had much luck with the car as of late. Noticed there was engine oil coming out from the bell housing and whilst under there, I also noticed oil coming from the turbo between the cartridge and turbine housing.
Pulled the box out haphazardly as I didn't have a hoist and pulled the turbo back off too. I cut the rear main seal by accident when installing it on the stand without being able to see the back of the crank. Turbo went back to MTQ for warranty and they reckon nothing was wrong but replaced the oil seals.
Fitted new rear main which is an absolute f**k to get in there and box and turbo back in for test drive.
I put new viscous oil in the fan hub last night and it works/sounds like it's moving a lot of air now. Went to go for a drive, look under the car for leaks after putting it all back in andddddddd oil is pissing out of the turbo feed banjo. FML. I checked every fitting was tight before I put it back in so MTQ have done something there.
So today I started pulling the turbo back off again to fix that.
20 minutes ago, andynogo said:
Yeah... It's one thing after another hey. Keep on trucking- you'll get there! Half price boost night 17 April at whoop ass... Might be a few of us going...
I would but i'll be on arvo shift. I plan too make it down there soon before seasons end.
So it's back in business, no leaks so much success.
Hob drive still says its overheating though but the gauge does not move whether it's 75 or 105.
The new fan oil helped a bit but I think it might be a faulty sensor.
  • 3 weeks later...
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
