23 minutes ago, andynogo said:
Sorry to hear Brendan. Good luck dude. If you need a decent low k motor there is one up at the moment that I was thinking of buying but your needs are greater... Stagea WA page on Facebook about a week ago.
I should be alright. I drove it back home from the plex so hopefully I can just gone and re ring it. I still have the original motor here too so worst case I just build up another short block.
On 4/28/2019 at 5:13 PM, andynogo said:
Hi Brandon, any updates or are you taking a break from it for a while? (That's what I do when this happens to me!)
It's up on jacks and I've almost got the rad support off. Just plodding along with it when I feel like, no motivation haha
6 hours ago, Ben C34 said:
Might have missed it, but what is the ecu situation in the car?
Itsrom flash tune, tuned for 18psi. Saw a peak reading of 18.7 on boost controller so it's most likely leaned out over the quarter mile.
Got one head off to look at number 6. It's definitely gone lean, you can just see some detonation on the crown of the piston and at the very top of the bore. Then it's just scraped away at the bore and likely the piston skirt.
I might be able to plate hone it out to the limit but I think it may have been pretty close when I originally honed it.
Edited by Sack87
Eww. Looks like the rings have picked up bits of the piston edge as its burnt away there... The bore might clean up but that piston is fubar... Fingers crossed for the bore!
I wouldn't have thought it would lean out that badly at 18psi... What fuel pump do you have? I only ask as I recently received a genuine Walbro from a verified seller... It was a fake. Fine for an excel but not for a thirsty birch like our Stageas! Looked very close but had the cheap plastic vanes instead of the metal pump gears.
Stock pump still. Christian asked me what pump I was running when I was looking at his flash tune at the time, but it seems we missed out relaying that info to each other.
Note to self, stock pump is no good for 18psi.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
