21 minutes ago, andynogo said:
Well I've got a100 cell cat and a blitz nur 80mm exhaust and it's too quiet! But of drinking at 2500rpm which I might tune out of i cbf...
So turbo smoke all gone with the fancy oil supply regulator?
Yeah no more smoke. Getting ready for tune. Just need to buy some injectors now.
  • 4 weeks later...
1 hour ago, Ben C34 said:
What is the cutout? Boost activated?
Normally closed, boost activated. It opens at around 3psi instead of the stated 14psi so I need to put a boost tee in the line to open it later. It's stupidly loud hahahahaha
  • Like 1
I found the back pressure in my exhaust would prematurely open the valve. You may find even with a bleed valve it may not want to stay closed. Have you tested it with the boost line disconnected ?
With mine closed my fueling requirement dropped by 13% and timing had to be retarded up top by approx 4 degrees. other wise exhaust manifold pressure/gas would creep back into the cylinders at high rpm and cause knock.
I’ve read through your thread and I’m going to go out on a limb and say the EMU isn’t safe to use on your setup. The turbo you have is quite stout which makes the sensitivity of your engine to an improper tune substantial. The time spent rebuilding engines and constantly touching up the tune will justify moving to a safer more suitable option like the LINK fury ecu.
Benefits are substantial:
-automatically adjust fueling based on fuel pressure so risk of leaning out is greatly reduced
-Ability to simulate MAF output to keep the transmission happy when running a MAFLESS tune
-No hot start problems that you get with the EMU when trying to balance correct injector lag times vs injector size compensation.
-Full rpm & load closed loop wideband fuel compensation
-Gear based fueling&ignition timing
-CAN bus integration to retard timing and boost during OEM torque reduction requests for gear change. I think I may be the only one with this working atm
-CAN bus integration for Gear Position status in tiptronic mode. Again not sure if anyone else has the message IDs identified for this
-ethrottle control for torque reduction at high rpm. Solves the over rpm issues when trying to change from 1st to 2nd under big power. Enables the rev limiter to be soft on the engine.
-Cam Angle Ignition and Fueling compensation.
-Perfect tuning gauge display is plug n play
-perfect hot & cold starts
-Flex fuel tuning for any combo of E85 and ULD
-Fuel Temperature compensation
-Anti-Lag
-Cruise control
-proper data logging
-proper individual cylinder knock control
-etc etc etc
As you can see what you get for the extra $ makes a substantial difference to your ability to mitigate against unstable combustion, ie engine damage. Also protection of the transmission. I’ve been through 5 gearboxes and 3 engines so learnt a lot along the way.  First M35 325awkw. Second M35 411awkw
Matt
  • Like 1
  • Thanks 1
It's slightly open at idle so I need to put some more preload on the actuator. Even if it opens at 10psi I'll be happy.
EMU was cheap, Link is not. Basically it all comes down to money. Maybe later on I will go that route since I have made the harness plug and play.
What boost were you running on the EMU 98 tune (that's the one I'm going to put in and have the tuner touch it up)
It was running 26psi.
Following this stage with great interest. I've for almost three same mods Brendan- and an EMU as well. I would love to go Link like Matthew has but at 3-3.5k tuned is just too much at the moment... and would be a massive over-capitalisation in my car. Having said that, I'll probably be disappointed with the EMU in the long run and and up going Link!
  • 4 weeks later...
  • 3 weeks later...
So you driving this yet? Wondering how the hi stall is? Wondering if i need one after last night's drag racing stalling effort....10+ secs to get just over 3000rpm. Trouble is that it's the wife's car so need something that drives almost normally.
Yeah man it's my daily. High stall is a must with what you plan on doing.
It's a little bit doughy when I'm taking off but that's expected as it needs more revs to get it moving. When it's at the right rpm and ready to go though, it's like a freight train.
Mine still takes about 10 seconds to stall up and gets to 11psi. It can make more once I get it tuned and get some more fuel in there down low.
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
