Cheap R33 bits in Adelaide
I'm cleaning out my workshop, and have some cheap bits for sale:
R33 GTST Passenger's seat - bit dusty/dirty but in pretty good condition $5
R33 GTST Aircon bits - compressor, engine bay lines & condensor $20 Was working when removed a few years ago
Space saver spare wheel/tyre from 350GT - 5x114.3, T145/90D16 tyre never been on the road $40
R33 GTST electric radiator fan (for aircon) $20
R33 GTST Airbox & snorkel - snorkel has a small bit cut-out to clear alloy radiator, includes an air filter $40
R33 GTST stock side-mount intercooler $10
R33 GTST Coupe headlining in reasonable condition $10
RB30 sump (also fits RB25/RB25DET) has a small split. Ideal for someone who wants to put extended wings on (or use as exchange for extended sump) as the split is where the wings go anyway $40
Pair of Nankang NS-2R semi slicks, nearly new tread depth, 120 tread wear rating, 255/40ZR17 $80
Happy to post smaller items at cost. Not posting whell, tyres seat, headlining. Pics on request.
  • Like 1
https://www.sau.com.au/forums/topic/471249-cheap-r33-bits-in-adelaide/
On 14/07/2017 at 3:01 PM, GeeDog said:
R33 GTST Passenger's seat - bit dusty/dirty but in pretty good condition $5     Sold
R33 GTST Aircon bits - compressor, engine bay lines & condensor $20 Was working when removed a few years ago    Going in the bin this week
R33 GTST electric radiator fan (for aircon) $20   Going in the bin this week
R33 GTST Airbox & snorkel - snorkel has a small bit cut-out to clear alloy radiator, includes an air filter. Now has small bit broken on 1 mounting tab - doesn't affect mounting $40
R33 GTST stock side-mount intercooler $10    Sold
R33 GTST Coupe headlining in reasonable condition $10     Going in the bin this week
Pair of Nankang NS-2R semi slicks, nearly new tread depth, 120 tread wear rating, 255/40ZR17 $80    Sold
Updates above
Hey mate.
Could you hold on to the A/C compressor? Willing to take it off your hands if you could ship to Sydney for me?
I could even arrange the courier if you could put it in a box and flick me dimensions?
Cheers.
11 hours ago, inmaniac said:
Hey mate.
Cheers.
Sure - pm sent
On 7/16/2017 at 7:51 PM, GeeDog said:
Updates above
R33 GTST Aircon bits - compressor, engine bay lines & condensor $20 Was working when removed a few years ago    Sold / binned
R33 GTST Coupe headlining in reasonable condition $10     Binned
R33 GTST electric radiator fan (for aircon) $20   Going in the bin this week Binned
R33 GTST Airbox & snorkel - snorkel has a small bit cut-out to clear alloy radiator, includes an air filter. Now has small bit broken on 1 mounting tab - doesn't affect mounting $40 Sold
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
