Cheap R33 bits in Adelaide
I'm cleaning out my workshop, and have some cheap bits for sale:
R33 GTST Passenger's seat - bit dusty/dirty but in pretty good condition $5
R33 GTST Aircon bits - compressor, engine bay lines & condensor $20 Was working when removed a few years ago
Space saver spare wheel/tyre from 350GT - 5x114.3, T145/90D16 tyre never been on the road $40
R33 GTST electric radiator fan (for aircon) $20
R33 GTST Airbox & snorkel - snorkel has a small bit cut-out to clear alloy radiator, includes an air filter $40
R33 GTST stock side-mount intercooler $10
R33 GTST Coupe headlining in reasonable condition $10
RB30 sump (also fits RB25/RB25DET) has a small split. Ideal for someone who wants to put extended wings on (or use as exchange for extended sump) as the split is where the wings go anyway $40
Pair of Nankang NS-2R semi slicks, nearly new tread depth, 120 tread wear rating, 255/40ZR17 $80
Happy to post smaller items at cost. Not posting whell, tyres seat, headlining. Pics on request.
  • Like 1
https://www.sau.com.au/forums/topic/471249-cheap-r33-bits-in-adelaide/
On 14/07/2017 at 3:01 PM, GeeDog said:
R33 GTST Passenger's seat - bit dusty/dirty but in pretty good condition $5     Sold
R33 GTST Aircon bits - compressor, engine bay lines & condensor $20 Was working when removed a few years ago    Going in the bin this week
R33 GTST electric radiator fan (for aircon) $20   Going in the bin this week
R33 GTST Airbox & snorkel - snorkel has a small bit cut-out to clear alloy radiator, includes an air filter. Now has small bit broken on 1 mounting tab - doesn't affect mounting $40
R33 GTST stock side-mount intercooler $10    Sold
R33 GTST Coupe headlining in reasonable condition $10     Going in the bin this week
Pair of Nankang NS-2R semi slicks, nearly new tread depth, 120 tread wear rating, 255/40ZR17 $80    Sold
Updates above
Hey mate.
Could you hold on to the A/C compressor? Willing to take it off your hands if you could ship to Sydney for me?
I could even arrange the courier if you could put it in a box and flick me dimensions?
Cheers.
11 hours ago, inmaniac said:
Hey mate.
Cheers.
Sure - pm sent
On 7/16/2017 at 7:51 PM, GeeDog said:
Updates above
R33 GTST Aircon bits - compressor, engine bay lines & condensor $20 Was working when removed a few years ago    Sold / binned
R33 GTST Coupe headlining in reasonable condition $10     Binned
R33 GTST electric radiator fan (for aircon) $20   Going in the bin this week Binned
R33 GTST Airbox & snorkel - snorkel has a small bit cut-out to clear alloy radiator, includes an air filter. Now has small bit broken on 1 mounting tab - doesn't affect mounting $40 Sold
    • Hi all. So I have my GTR on the lift and have been working on it a few days and today I unpacked the frontpipe that was wrapped with heat wrap stuff, because part of it was breaking down and soaked in oil. Noticed that the pipe itself does not actually look like a Mines, despite it supposedly being a Mines. But I could not find any fronpipe online that looks exacly like his, and I don't think it is a custom one. My amateur measurement also showed the two pipes are about equal length, so maybe this is just an old version of the Mines pipe? Would appreciate insight on this by the enlightened folks. greetings from Germany
    • Yeah. If I plug the connector in and connect the vacuum lines, I assume worse case scenario is that it simply doesn't work? Yep PFC.
    • I would think that rather than attempting to perform an engine swap, with all the difficulties associated with doing so in a country where the raw materials required are harder to get hold of, I would just build the CA20 for boost, find an EFI manifold for it and either add a turbo or a supercharger. Or both. You replace one set of difficulties with a different set, but I know which would be more fun.
    • Well, a proper aftermarket ECU** SHOULD be set up to run the purge solenoid, same as the factory ECU would, so that the tank breather system continues to operate the way it is supposed to. I have no knowledge of whether the PFC (which is what I assume you mean when you say Apexi) has an output (and internal logic) to run the purge solenoid. If it does not, then given the product design intent for the PFC, which is to be a plug in replacement for the stock ECU, I would consider that a massive failing on Apexi's behalf and would be another reason to think that they were a half-arsed solution to the problem if programmable management on RBs. I would suggest that since Nistune came to market (which is a LOOOOONG time ago now) there has been no valid argument for choosing a PFC, especially if the PFC can't do things like this.   **ie, Haltach, Link, Motec, etc
    • Thanks for asking the question we were all thinking!
