Skyline
Hi
Can anyone plz tell me is that true 2006 infiniti g35(280 bhp) and 2008 skyline type sp v36(317) have diff bhp
If so which one is best ovrall(performance,suspension,relibility etc
My frnd had 2006 infiniti and im gng to get mine 2008 skyline 350 gt type sp soon.
Plz tell me what the extra features( shape, interior,performance, handling etc) ill get on mine car as compare to 2006 infiniti.
Im askin bcz i havnt seen my car yet physically as it is in transit frm japan.
Thnks
https://www.sau.com.au/forums/topic/471262-skyline/
Hey mate.
You'll find this forum very accommodating, helpful and friendly, until you ask things without doing any research yourself, and putting little effort into your posts.
Objectively, a V36 is better than a G35. They are, however, extremely similar.
The V36, in the spec you listed, comes with the VQ35HR, an upgrade from the VQ35DE found in the G35.
The V36 includes updates and enhancements to the chassis (stiffer) and a better tiptronic, if you go auto.
I found this info in less than 5 mins. :1310_thumbsup_tone1:
https://www.sau.com.au/forums/topic/471262-skyline/#findComment-7840140
G35 could be a V35 chassis or V36 chassis, if it is a V35, it will have the VQ35DE (280hp) or VQ35DE revup engine, if it is the V36, it will have the VQ35HR like the V36 skyline 350GT.
unfortunately just the label 'Infiniti G35' doesn't define which chassis it is.
https://www.sau.com.au/forums/topic/471262-skyline/#findComment-7840737
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
