Bought a brand new coolant bottle, bonnet cowl and rubber, new clips for the front grill.
Also got a new GTR badge for the boot, original GTR key and a nice little Nismo key ring emoji16.png
Will start fitting things this weekend, also going to wire in my sub and amp and tune the stereo. I've also changed the steering wheel to my mono 'race' wheel.
When I got time I'll post my list of things I have decided to do.
  • Like 1
https://www.sau.com.au/forums/topic/471263-gtr-i-just-got-one/
Well spent all day on the GTR today, got the stereo finished, Bluetooth deck with full phone integration, sound stream 12'sub and amp, also has digital radio which is nice. Cleaned up a few little things whilst installing and put in a few interior screws where they were missing.
On a downer it appears to have broken an engine mount and as a result the bonnet won't shut [emoji848]
So off to mechanic to get it checked out.
Also what I thought was a noisy thrust bearing may be input shaft bearing on the box. Called award about a rebuild, thinking of doing full rebuild with billet flex/sandwich plate to strengthen the box.
Has anyone on here had the billet plate installed and how has it held up? I want to also throw in a twin plate Nismo clutch but have to see how the budget is, still a lot I want to do [emoji849]
  • Like 1
I'll post a pic tomorrow, it's in the boot, drivers side with the amp mounted to the box, wires run under the carpet on the drivers side, I did the engine bay to interior by following a wire that was fitted by Croydon when they ran a direct line from battery to fuel pump. Goes through the guard to the drivers footwell. Had to remove the wheel and splash guard on the drivers side, gave it a good clean while I was there
Rob Award gearbox and diff quoted me $2300 for a full rebuild and billet sandwich plate. The sandwich plate is the weak link in the 5 speed GTR boxes. They said it's rare for a box to come back once it's been fitted with the billet plate. I'm not running huge power so figure, do it once, do it right. The box in the car has been going to 12 years and there is noting wrong apart for the input shaft bearing. It still shifts perfect, no crunches. But according to the last rebuild receipt it was upgraded to R33 spec so should have stronger syncros.
Where I'm stuck is I need to do the box before it lets go and does more damage but I want to do the clutch as well and all up that's about 6k. Don't have that much to throw at it right now, so might just throw a second hand box in it then have my box rebuilt, buy the clutch then swap it over.
Well took the car to mechanic this week, service and hooked up heater hoses, was great having a heater, until I realised it now only heated!
After speaking with a mate he was able to point me in the right direction and a quick search on the forum found my problem. Air temp sensor wasn't plugged in, in fact it wasn't there!
Went through my parts, found three of them, one connected to this mint smooth finish surround so I decided to fit the entire surround.
Very happy with the result and i can how have heat or cooling [emoji16]
If anyone has a smooth black ash tray they are willing to sell pm me please. Must be in mint condition. The one I have is good, not great so I'll replace it.
The other day I took to car to Hume mufflers, cut the centre muffler out [emoji848]well it's loud now [emoji15]
Got quoted for a full custom stainless 4' system. So that's now on my list of things to do.
Also been offered a full single turbo set up, contemplating getting it? What turbo is it GC?
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
