Custom shroud and 16’ Spal fan. And the battery is being relocated to the boot with a under bonnet surge tank being fitted. All the aftermarket wiring and relays are being  removed and it will all be controlled via a PDM.
I also bought a PRP coil pack bracket and stalks so I will be able to fit the valley cover back on, it’s been coated and fitted with a new R34 ornament plate.
  • Like 3
3 hours ago, Ben C34 said:
Under boner surge tank seems questionable, what's the thinking behind that?
For me, it’s to fill the space where the battery sits once it’s relocated to the boot. Benefits are better and more consistent  Fuel pressure, as the lines from the pumps to the rail are now significantly shorter. The rear of the car reverts back to standard with the only mod being the rubber lines upgraded to something e85 compatible. So no more aftermarket lines from the rear of the car to the front.
I never had this issue but also for set ups that suffer from fuel smell in the cabin, this eliminates that.
The only downside you might be able to argue is would the tank suffer from heat soak from engine bay heat? I can’t see this being an issue with where it’s mounted, on the cold side of the motor and furthest away from the motor. And it doesn’t just sit in place, it’s mounted in place so can’t move.
What are your thoughts on it Ben?
the heat soak is my main concern. I know drag cars do it, but they are hardly on so not a good reference!
As for the fuel pressure benefit, I dont think that is really an issue is it? Any half decent ecu can compensate for fuel pressure with a sensor (that you would surely run) if there is some discrepancy.
I imagine you have a flex sensor? they measure fuel temp also so depending where it is mounted you will tell if there is a heat soak impact of having the surge tank in the engine bay.
I get it makes for good use of space, but it does seem a bit bad in a crash.....
  • Like 1
  • 1 month later...
Well, it’s getting there, car is almost done, dash configuration is being completed, (it looks good) and the last bits and pieces are being fitted. With a bit of luck might have it home some time next week.
  • Like 3
So you're retaining the factory top hat with 5/16 in/out fittings, factory hard lines and 5/16 feed/return from surge tank to main tank ? What intank pump are you running ?
Yes, I believe this is the case, I know 100% they used the factory top hat and hard lines. I’ll have to look at the invoice to confirm but I believe they used a 255lph pump in main tank and two 460’s in the surge tank.
21 minutes ago, DaymoR32 said:
That looks amazing!
Thanks Daymo, I’m very happy with the result, not sure if you noticed but there are shift lights in the tacho, oil pressure gauge also gives oil temp, water temp gauge give water pressure, fuel level gauge gives fuel pressure, and where the trip metre should be gives boost.
  • Like 1
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
