Well, after almost 3 months, tomorrow is the day, when the GTR comes home...for a bit. An extensive amount of work has been completed, marking another step in the cars evolution. Still a long way to go before it’s finished, but I’m happy that a lot of the ‘little things’ are now sorted.
The car went on the dyno to sort out a boost creep/spike issue, it had a blend of 98 and e85 and was at about 15% ethanol content. It made 420 awkw on the rollers @20psi (gate pressure) and that’s wearing Toyo R888 tyres.
looking forward to getting it back and taking it for a run.
  • Like 5
  On 30/09/2020 at 9:54 AM, PranK said:
Fantastic! And she looks great too!
Hey, any chance of a video of the dash working? A few keen beans on insta have asked.
Expand
No problem, I’ll get one up on the weekend
  • Like 1
Yes, it’s really nice. Was good to drive the car again, forgot how bloody fast this thing is. Even on gate pressure running 98 the thing is an animal on the street. But you can feel the reduced power in the top end, but it’s really strong through the mid range.
I found out the motec uses the wheel speed and rpm. The gear ratios have been entered in so it can determine what gear it’s in. Actually works really well.
  • 7 months later...
Well this never ending build is finally moving forward. Car is going to the shop after GTR festival to have the motor removed, then it’s off to get the bay painted, then the new 2.7 stroker motor is going in. I’m also replacing the cooler to a Plazmaman 100mm comp spec and the entire hot side. Going a 6boost manifold with egt bungs for each cylinder and new turbo will be a Precession 6875.
And while I’m there Pro wire will be making me a new custom engine loom and cleaning up all the other wiring in the bay.
after this I’d like to think the bay is finished? If there is such a work in the GTR world 🤔
  • Like 1
  On 24/05/2021 at 12:50 PM, MoMnDadGTR said:
nice unit mate, hell of a read. that dash is wicked too
Expand
Cheers, it’s been a long road, with many ups and downs. Hopefully at some point I’ll get it to where I want it.
Expand
Ahh don’t get to caught up in the details mate. Don’t get me wrong you have done a job I couldn’t never do my engine is a hack compared to that lol. But it’s good to be content and enjoy what you have! Your car is wicked mate go bag the piss out of it. Cheers.
  • 3 weeks later...
Well, I’m going back to a 2.6 based motor, just in the process of getting everything together, things getting re-furbished, coated or replaced with new where I can. Car is at the painters now, decided to paint the bay the colour of the car. Also sold my hotside so it’s being replaced with a 6 boost manifold and 68/75 turbo. I’ll also be running egt’s and getting a new engine harness . But one thing at a time 🤔
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
    • Well, the NA RB25 is nothing special in terms of the amount of power it makes stock, nor with any easy mods like extractors & exhaust, opening up the intake tract, etc, etc. And just like any small capacity NA engine, getting lots of power out of them takes a fair bit of money and, depending on how far you go with big cams and high compression and so on, quite grumpy to drive. So, boost is the answer. Many many many of them have had a turbo added. This is easy enough. Same as for any engine. Need the things you need to bolt on the turbo of choice, fuel system and management upgrades, clutch, stronger gearbox ( you do not want to run a boost RB25 through the NA box), diff, brakes, etc, etc, same as you would for most other NA+T things. Some much smaller number have had a supercharger added instead. These are good and cool, but have nowhere near the potential of the turbo route. All the same required upgrades apply. So, potential? Anywhere from not much to quite a lot, depending on how much effort and expense you want to go to. Is there value in the effort and expense? Objectively, no, there is not. If you're gaining enjoyment and don't mind blowing a lot of money on the project, then that's where the value is. Parts? Nissan dealers for some. Many many on-line vendors who do Japanese manufacturer spares (buy buying them from disposals at dealers around the world, direct from manufacturers, increasingly from Chinese knockoffs, etc) and warehousing them in Dubai or similar places. Amayama, Partsouk, etc etc. There are quite a few. Some local to Australia, some local to Europe, some local to the US. You can upgrade literally everything. For an NA, unless you're going to boost it, there's little point going past a nice exhaust, as I said above. After that (well, actually probably even before that) you should concentrate on making it handle the best it can, good brake components, light wheels and tyres, and just make it something to enjoy throwing through the curves. You'll never, ever win any drag races, so it needs to be taken as a nice point-to-point car. Throw in some Recaros or Brides, nice Momo wheel and gearknob, so it's pleasant to be in (because god knows, the inside of an R33 is not a pretty place!!) and away you go.
    • How many $$$ do you have to slip cams to logbook a car that’s not the orginal to the 1990 standard lol
    • Thanks for the update I truly appreciate it. I was trying to figure out the sensors.
