Got a couple of more deliveries today, steering rack was done and dropped off for coating, should be good to get the front subframe in the car in the next couple of weeks. Be good to actually start putting it back together.
  • Like 2
On 22/4/2022 at 7:52 PM, r32-25t said:
Must be nice to have forward progression
Just getting stuff done/ ready, forward progression will be when the front end is back in. Active we’re really good, got the rack turned over in 24 hours, wish all the shops were that efficient
On 23/04/2022 at 8:37 PM, Old man 32 GTR said:
Picked up an uncut bonnet today.
Absolute bastard 😤
If that was under 2k I'm impressed. The old man is bugging me to change our white 32 back to stock but everyone wants a pound of flesh for them 😡
On 23/4/2022 at 11:38 PM, BK said:
Absolute bastard 😤
I paid $2700 for it, I remember when bonnets were under 1k, some are asking 4K+ for them. All you can do is put the feelers out and see what pops up, I did a WTB add on the FB GTR groups, got about 4-5 responses, so they are out there, but like you said, pound of flesh, some want 2 pound! Lol
Twin scroll manifold, with pulses split to the gate, looks the business!
Silly to go single scroll these days, not sure why go many big setups still do this when you have beautiful manifolds like that!
On 07/05/2022 at 12:46 AM, r32-25t said:
Only reason is because a lot of turbos aren’t available with twin scroll housings any more
Blame Murica, they're too busy doing twin turbos on everything they can find.
And from an educated guess, they're the world's greatest consumers of turbos and soon RBs lol.
Well with a 7675 strapped to it, I’ll need all the help I can get to get it on boost.
  • Like 1
On 27/03/2022 at 8:38 AM, Old man 32 GTR said:
That is all suitable, They can even do plastic parts, he showed me a fuse box cover from a VL he did, looked brand new. I’ve given him a few plastic parts, I’ll post them when I get them back.
Thanks for the info.
Received my first batch of Cerakoted parts today and they look so nice and OEM.
This will become an addiction. Bye bye bank account balance.
  • Haha 1
Awesome, amazing what they can do and makes a huge improvement on the look of the car.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
