Custom shroud and 16’ Spal fan. And the battery is being relocated to the boot with a under bonnet surge tank being fitted. All the aftermarket wiring and relays are being  removed and it will all be controlled via a PDM.
I also bought a PRP coil pack bracket and stalks so I will be able to fit the valley cover back on, it’s been coated and fitted with a new R34 ornament plate.
  • Like 3
3 hours ago, Ben C34 said:
Under boner surge tank seems questionable, what's the thinking behind that?
For me, it’s to fill the space where the battery sits once it’s relocated to the boot. Benefits are better and more consistent  Fuel pressure, as the lines from the pumps to the rail are now significantly shorter. The rear of the car reverts back to standard with the only mod being the rubber lines upgraded to something e85 compatible. So no more aftermarket lines from the rear of the car to the front.
I never had this issue but also for set ups that suffer from fuel smell in the cabin, this eliminates that.
The only downside you might be able to argue is would the tank suffer from heat soak from engine bay heat? I can’t see this being an issue with where it’s mounted, on the cold side of the motor and furthest away from the motor. And it doesn’t just sit in place, it’s mounted in place so can’t move.
What are your thoughts on it Ben?
the heat soak is my main concern. I know drag cars do it, but they are hardly on so not a good reference!
As for the fuel pressure benefit, I dont think that is really an issue is it? Any half decent ecu can compensate for fuel pressure with a sensor (that you would surely run) if there is some discrepancy.
I imagine you have a flex sensor? they measure fuel temp also so depending where it is mounted you will tell if there is a heat soak impact of having the surge tank in the engine bay.
I get it makes for good use of space, but it does seem a bit bad in a crash.....
  • Like 1
  • 1 month later...
Well, it’s getting there, car is almost done, dash configuration is being completed, (it looks good) and the last bits and pieces are being fitted. With a bit of luck might have it home some time next week.
  • Like 3
So you're retaining the factory top hat with 5/16 in/out fittings, factory hard lines and 5/16 feed/return from surge tank to main tank ? What intank pump are you running ?
Yes, I believe this is the case, I know 100% they used the factory top hat and hard lines. I’ll have to look at the invoice to confirm but I believe they used a 255lph pump in main tank and two 460’s in the surge tank.
21 minutes ago, DaymoR32 said:
That looks amazing!
Thanks Daymo, I’m very happy with the result, not sure if you noticed but there are shift lights in the tacho, oil pressure gauge also gives oil temp, water temp gauge give water pressure, fuel level gauge gives fuel pressure, and where the trip metre should be gives boost.
  • Like 1
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
