Mick_O's Detailing Diary
Hey guys!
I've always detailed my own cars forever and have done a couple of detailing courses with SAU & alot of online research over the years. After the 1st course i ran out and bought a neat little random orbital polisher (Mint DAS6) which is a great little unit for the money and has never missed a beat ?
But after playing around with some serious gear my mate (That Detailing Guy) had i realised how much of a toy my lil DAS6 was!
So a few months ago i splashed out on some nice new toys and have had some fun in the shed with some friends and family cars.
So thought id share some pics of my new toys and the results I've got with them ?
https://www.sau.com.au/forums/topic/471268-mick_os-detailing-diary/
So this bad boy the the Flex 3401 Forced rotation polisher its a 900W beast!
Im a pipe fitter/ pressure welder and spend alot of time hanging off 9" grinders and this thing commands the same respect lol. Sure its not gunna cut your arm off but it takes some muscle to hang on to ?
So this little guy is a Flex PE-8 its an 800W rotary polisher. I f**ken love this little guy!
I have backing plated from 3" down to 1" and with the extension bars that i have there literally isn't a place i can't get to ?
Picked up some cheap LED worklights off fleabay to help me see those defects!
Had the stands floating around in my workshop so it retrofit the LED's onto the stands ?
4×150W LED's are nice and bright and dont give off any heat like halogen light which is good when you're going hard at it!
Last but not least is 1 of my favourite things! The trusty foam lance... AKA the jizz gun for short! ???
Again this is used as a preventative measure to stop you scratching your car up when you wash it by dragging dirt across your paint with your sponge or mitt ?
Heres Dads 370GT after i touched her up and threw a coat of HD Nitro coating on her. Its a really great easy product to use and is quite well priced!
No i hadn't done the wheels as the weather was turning crap and time wasnt on my side lol
So just look at the paint ?
Edited by Mick_o
Heres my sisters fiancee' E9 that i prepped and sealed again with Angelwax Ti-22 titanium paint sealant followed up with Angelwax fifth element wax (expensive shit!) But looks amazing and is great to work with goes on and comes off very easy!
  • Like 3
Here's my boys mums SP23 i corrected and coated in the same products as the Evo 9 above ?
Actually 1 of the few cars i remembered to take some before and after shots ?
The paint on this is R.S unfortunately but still comes up great for an 11yo car. This was around a 15hr correction though lol.
So before....
As always black looks amazing for about 45 seconds after its been coated!
That Angelwax Ti-22 & fifth element wax is an amazing combo though.
Even made dads 2.5yo lil wing nut smile ?
Edited by Mick_o
So here's a mates young blokes MX5 i done a couple of weeks ago. This thing looked like spiderman had wiped his ass all over this thing it was quite munted indeed! Typical Mick_O style rips in and forgets to take before and after shots to compare! ?
But i basically gave it foam lance then a 2 bucket wash followed by a clay bar and rinsed then hit with HD adapt (best compound out there!)  and a blue pad which was a medium/heavy correcting pad then threw a coat of HD poxy over it. Even a small little car with no roof like that still took 5hrs!
But still came out great!
Im a huge fan of HD products they are quite well priced and deliver amazing results.
Puts anything you get from SCA or your local autobahn to shame for not alot more really ?
Last and hopefully not least is me old mateys shitbox i tickled up for him. Cos im a top bloke of course!
So this nugget got the foam lance treatment then the 2 bucket grit guard wash then decontamination with Angelwax clay sponge then hit with Angelwax regenerate compound then sealed up with Ti-22 titanium paint sealant followed up with Angelwax Dark Angel black hard wax... But as you can see she came up ok ?
  • Like 2
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
