Hey ppls,
Well, I've made my kit up and it works great. Takes some tuning to get it right, but when it's right, it goes great.
Kit will come complete with two valve and check valve, as described in Autospeed articles Autospeed article
Valves will be mounted to a bracket, all you will have to do it mount the bracket and plug in your boost lines.
Price change : $130 (plus shipping which will be $15 anywhere in Australia)
I will require payment up front, and the kits should be ready in 7-10 days.
See attached pic for the example of what it will look like.
Current people in buy are
ADZMAX
SKYLINEGEOFF
CEREALKILLLER
BASS OUT
https://www.sau.com.au/forums/topic/47127-group-buy-pneumatic-boost-control/
Okay, I noticed the following.
The thing takes a little while to set up, but once set it says set.
Tranisent boost response, ie getting on the throttle in higher gears is much better, insted of slowly building, it just goes straight up to full boost.
First gear is not all that noticeable simply because my car revs out so fast in first anyway.
But spooling is definently quicker.
BASS OUT
Possibly interested...
Do you just mount in the normal position between the presure point and actuator? I'm a bit of a dumb arse when i comes to the mechanics of the turbo and am concerned i would not know where to install it...
So your saying the advantage is that the boost comes on quicker than a normal single stage controller? I read in your first page on this that it acts more like a Electronic Controller. Is this correct?
Regards,
Jeremy
PRICE CHANGE. NOW $130 complete
GOT SOME BETTER QUOTES FOR THE PARTS.
Need at least 5 people though.
If we get 10, then price drops to $125 each.
BASS OUT
I'm in for sure. These things are great and the theory is sound. The fact you can controll how quick and how strong boost comes on is awesome. I run a standard bleed at the moment and was keen to get one of these kits just could never be farked building it :)
This is a slightly neater way to do it Later on I put it inside the cold air box
http://www.skylinesaustralia.com/members/5...takes%20003.jpg
Hey Jay,
I notice you've got the upgraded pressure regulator there. Did it make a big difference in controlling boost? was it worth the extra $$$???
Zahos
That's a good question and something that I might investigate.
I drove to Bendigo and back today and had a lot of opportunities to play with the boost control, mainly slowing down to 80 and dropping it up to 110 (legal limit) to see what the boost does in each gear.
What I found is that the boost will spool to the set level (first valve) in first and second no problem, but then third gear, it would boost to set level and then drop right off, like the wastegate was flying open.
The boost would eventually build to the peak level, but not until 5-6k rpm.
So tonight when I get back, I removed the new second valve (peak boost valve) and replaced it with my old bleed.
Problem solved.
I'm going to investigate another valve that I'm sourcing and try it on my car first.
I hope you all appreciate this!!
BASS OUT
I think it's probably not worth the extra cash. the system works well with the one way valve ensuring that the line to the wastegate loses any contained boost pressure as soon as you take your foot off. If you'r finding that boost builds too slowly it's possible that the wastegate is starting to open too soon. This is controlled by the other valve.
I found that the system is sensitive to it's ambient temp. In the Audi it sits against the firewall on the cool side of the motor ( The origional car lives on the Gold Coast) The usual mount point in the Skyline is in a place that can get hot. Thats why I moved it inside the airbox
The reason I finally removed it was I couldn't keep the same boost in all gears, eg 1.2Bar in 1 and 2, 1.4Bar in 3 and up to 1.7 bar in 4th + an E-Boost came up at a good price.
I never had a problem with slow boost buildup or falling off. I was on full boost by 3100rpm in any gear and at least 60%boost by 2700 rpm. It is a good system....but you need to really understand how it works and be prepared to fiddle to get it spot on.
After fitting the old Bleed valve, I now have the impression of the steering wheel on my forehead, as boost cut happened heaps last night.
Can't get it right.
I did have a little restrictor in the system before the first valve as one was fitted in front of the old bleed valve.
I have now pulled that out, but not had a chance yet to go for a drive.
I have to go out this morning at some stage so I'll have another play and let you know.
Can anyone explain this to me like im 7yrs old?
As I understand it a boost controller lets pressure out so the wastegate diaphram doesn't open and allows the turbz to deliver a higher pressure of boost . i.e. "boosted" car.
This looks like it has 2 valves? I read the autospeed article 3 times and still don't understand the difference.
Could someone explain this to me please?
:headspin:
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
