Here i have for sale
Ats super silent 2way lsd r200 abs 4.083 ratio
Was ats+lsd+.jpegin r33 but had to change the shafts to 6bolt
So will bolt in s14 or s15 200sx abs models or r32 r33 or s13 180sx abs models with the 6 bolt driveshafts i can supply for extra
The most streetable aftermarket 2way lsd as this is the super silent model which go for $1200 rrp for the centre only
Its currently filled with castrol lsx90 with penrite lsd additive and only chatters slightly when parking or moving very slow and turning
Its in excellent cond and locks up everytime
Had it inspected by bra diffentials before install and they said the clutches were like new less than 30% worn and backlash was perfect
Done less than 5000kms as i dont daily drive the car
Price $550 or $600 with driveshafts
Located syd west
Diff will be removed this weekend so can take anyone interested for a test drive till then
hi mate is this still available ? why is the ratio 4.08 is this factory r33 please
Yes still available
Was originally from a type x 180sx hence the ratio is 4.083 and why it has 6bolt halfshafts
Also is solid mounted at the nose which ill supply the bolts
Manual r33 is 4.11 but barely any difference both r200 diffs
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
