Goal = 400rwkw
I've got a fairly stock R34 GTT about to start modifying it to eventually reach my goal of 400kw. I've been looking into the precision 62/66 turbo as an option, sorta bias towards that option due to my mate having one spare I can get cheapish.
It ticks most of the boxes for the things I want in a turbo, only thing bothering me is that it is GEN 1. Is it worth saving for a GEN 2 62/66?
And it has a rear A/R of 0.68. will this be to small in a negative way? I think that a smaller A/R will give better low down tourq ect. Which is what I want, just doubting myself cause I see alot of recommendations for the 0.8ish size on similar size turbos like the gt3582.
Cheers!!
You'd want the CEA (ball bearing) version, and if you've got the budget to build a 400+kW Skyline then you won't shy at the cost of going with a split pulse/twin gate setup that's well designed (ie not a dodgy cheap China manifold and piping).
A 0.6x turbine housing would completely defeat the purpose of this size turbo, just choke the thing and frustrate you. I'd expect a decent setup on Neo 25 to perform best across 4500-8000rpm
An excellent alternative complete HTA3076 setup complete bolt-on capable of nearly 400kW is currently up for sale by 34GeeTeeTee. Well worth a look.
Im hoping for a turbo that has the potential to get to 400+kw but has decent response due to the car being driven on the street 90% of the time. From what i understand the 62/66 has the potential to exceed 400kw, but with the smaller A/R it will reduce the max hp output but increase the response. due to the turbo having the high hp potential (more than my goal) i can afford to loose some max hp and gain some response whilst still suiting my goals?
This is just how i understand it, please correct me if im wrong, still learning haha.
11 minutes ago, GTSBoy said:
Given that it's the wrong turbo, you'd better look at the various other turbo threads, especially the Borg Warner thread.
What do you mean by the wrong turbo?
cheers ill have a look at them threads!
Big flowing compressor needs to be matched with a turbine capable of flow.  Otherwise the engine effectively has a cork up its arse and can't breathe out.  So it won't get near 400kW, and streetable response isn't there.  Better achieved by using a different setup.
https://www.sau.com.au/forums/topic/426059-forced-performance-hta-turbos/?page=47
Edited by Dale FZ1
I have the Gen 2 6266 BB with a .82 rear housing... setup is not completely refined yet but its making ~20-21psi around 4700rpm, currently making 620hp on 23psi on a dynapack hubber..  forged 25 non neo with camtech cams and performance springs, the .68 rear will become a restriction as stated
Dyno sheet is in the rb25 thread
If you're on some what of a budget, don't discount @hypergear turbos. Their 45SAT will get you over 400kW and be decent enough to drive around town. I would recommend you go for the ball bearing version.
I've been believer of Hypergear Turbos since I started using them. I'm now on my 3rd Hypergear turbo (of course bigger each time) .
Yep you could always get the ss version of the atr45sat aswell
Think that comp wheel flows around the mid 400 mark
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
