Hi guys,
I am about to replace the stock turbos on my RB26DETT powered GTS-T. My questions are;
1/ Is it worth rebuilding the turbos and having them highflowed? How much to get this done? (Im in sydney)
2/ Has anybody done the work themselves? How complicated is it? Any special tools required?
3/ How much should i be paying in labour for a workshop to pull the old tubs off and put the new ones on?
4/ Can anyone recommend a workshop in sydney to do the work?
Any info would be much appreciated!
Thanks,
Lawrence
https://www.sau.com.au/forums/topic/47129-gtr-turbo-replacement-questions/
1) not really , there are plenty of deals on new terbs with better housings than spending the $2-2.5K rebuilding yours
2) No special tools, just a LOT of patience and do NOT bend the oil and water lines or you will be sorry.
3 )if they are straight replacement, we usually charge around $800 plus gaskets cos it's a prick of a job with the engine in the car.
4) Can't help you with that but stick to w/shops that know and have worked on these cars rather than go for just the cheapest price.
Cheers
ken
Thanks Ken.
How much is a gasket kit roughly? Is that a nissan original part?
I wrote another post asking whether the standard gtr ecu runs ok with N1 tubs or whether a Power FC upgrade is essential, it was suggested that you have a good amount of experience to answer that question!??
Thanks,
Lawrence
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
