Precsion 7675 fitting help.
MJTru
 Share
Hello everyone. I have a precsion 7675 turbo I got but it has a adaptor fitting on the top. But I'm not sure if that's how it should be. Can anyone help with the thread and pitch. I'm now looking to run my oil lines, and I'm stuck here. I live on a island and I don't want to order the wrong part or to many banjo bolts. Any help would be appreciated.
The thread is 1/8 npt. and when you do new fitting up hold the hex on this one to prevent it spinning. http://www.treadstoneperformance.com/prod_imgs/installation/ul/install-28.pdf
this is what you need if you are going to run a braided line like everyone else does. https://www.golebysparts.com.au/parts/view/990/152/golebys-parts-an-fittings-and-hose-oil-coolers-and-kits-/turbo-fittings-and-drains/1-8-npt-to-4-oil-feed-fitting
Edited by s13gtr
Had afew issues with my first built motor on start up.. long story short the inline filter saved the turbo from 5-6 pieces of debris that could have caused internal damage.. For an extra ~$80 it was well worth the tiny bit of hassle.. So many people told me it wasn't required and over kill but it saved me a turbo rebuild..
I have these filters and have always run them. Over the years I have done so on all my motors and service then on all oil changes. It's became second nature now.
 Share
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
