Blocking rb25det block heater hose fittings
Hi Guys
In the process of rebuilding my 25.
Since deleting the heater, i've always had the feed and return hoses looped, now the motor is out im looking to block the fittings completely.
The left fitting is threaded in. The right fittings looks pressed in. Am I ok to block these off instead of them being looped? The car is track only and looking to tidy up under the plenum.
Pic attached of fittings in question. Thanks for any help.
Did this recently on an RB25/30 build. We still have the stock oil filter/cooler fitted, and I ran a hose from each of the fittings circled in your pic to the oil cooler. I had to buy a couple of 3/4" to 5/8" (I think) brass adaptors - the fittings in the block are 3/4" (or 19mm), while the oil cooler hoses are smaller. If you aren't using the oil cooler, I'd probably put a hose between these 2 fittings. If you want to block them off you can get blanking plugs to fit - I bought heavy duty silicon ones off ebay to block some other coolant & vacuum pipes.
No idea - someone else may know. As I said, at the least I'd run a hose between the 2 outlets to keep the flow somewhat similar to stock. Ours has been on the track a couple of times since building the motor, and we've had no overheating issues.
  • 3 weeks later...
I'll have a dig around for the receipt for the threaded plug. Cant remember the size, i just took the fitting with me to get matched up.
The plug for the filter housing hole is about 18.5mm. Ended up getting a 3/4in welch plug and ground it down a touch and used some sealant. No leaks so looks good so far.
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
