Any members on here go to roll racing? I went to the last one as a spectator and went to this one last night as a support vehicle, but ended up entering and having a few runs...
And I have to say, had a ball, great fun and not too hard on the cars, I was rolling up to 50km/h in second gear then planting it at the tree, shifting at 7-7500rpm, car did very well, I was hitting 200-220km/h by the finish line.
  • Like 2
https://www.sau.com.au/forums/topic/471328-roll-racing/
Ive entered once before over here in Perth, The night was great and I enjoyed beating on the new setup but with traction issues and an old H pattern I was far from competitive, Its ashame it would seem the track over here at barbagallo is abit shorter 50-100m roughly then the eastern states.. doesnt give me enough time to catch back up after spinning 1st and 2nd. Good fun taking the misso and some mates for a blast though.. once my roster lines up again ill be keen again for sure...
Edited by azzada1
https://www.sau.com.au/forums/topic/471328-roll-racing/#findComment-7841400
hey mate think i saw you run a few times, I have the black r33 gtst- LETZGO plates.
Edgar's r33 won the event with his new tune, stupid quick.
Haha, I saw your car, very nice, and didn't Edgar's car have done mumbo! I'll def be doing that again, just got to iron out the little issues. Next time I see you, I'll come say hi
https://www.sau.com.au/forums/topic/471328-roll-racing/#findComment-7842984
Sounds good mate, I'll do the and if I see you. You going next Friday? I went last night to roll drags but after few runs getting boost cut so gotta sort it out
https://www.sau.com.au/forums/topic/471328-roll-racing/#findComment-7843039
Yeah I might come out this Friday, good fun watching the cars, don't think I'll enter though, I have to sort my box out, might see if I can get a support vehicle pass and bring the old girl out
Any idea what's causing the boost cut?
https://www.sau.com.au/forums/topic/471328-roll-racing/#findComment-7843183
At first I thought I blew the plenum piping off, cause it's happened before and felt the same.
Wasnt it, then got under the car to make sure I hadn't melted away my wastegate lines cause it dosed like 3 times consecutively. No luck there. Decided to test drive it on street and ran like a champ. One of those things, maybe just ecu went into protection cause of boost creep on such a cool night. Will just have to monitor and see what happens.
whats going on with your box? Mines on it's way haha
https://www.sau.com.au/forums/topic/471328-roll-racing/#findComment-7843249
Mines just got a noisy input shaft bearing, I bought a box on the weekend, going to take it to Award and have it rebuilt and put that in, then once I got mine out I'm going to have it checked to see if it actually has been upgraded to 33 spec, then I'll price up going a ppg gear set and billet flex plate. I'll build my box the way I want then drop it in with a Nismo twin plate clutch next year some time
https://www.sau.com.au/forums/topic/471328-roll-racing/#findComment-7843292
I'm not making huge power but just want it reliable. Making 360awkw but I'm changing exhaust (going custom 4' stainless) going to up the boost and might go flex tune. Hoping to be up around 450awkw if I go flex or 400 ish on pump fuel
https://www.sau.com.au/forums/topic/471328-roll-racing/#findComment-7843370
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
