frakzz Posted December 18, 2017 Share Posted December 18, 2017 8 hours ago, r32-25t said: What are the inducer and exducer sizes? Turbo Billet Compressor Wheel Garrett GT2860RS 813711-0003 (47.1 / 60.13mm) 6+6 Nose Dia. : 11.72 mm Inducer Dia. : 47.10 mm Exducer Dia. : 60.13 mm Extend Tapered Tip Exducer Dia. : 64.98 mm Tip Height : 5.21 mm Super Back Height : 2.30 mm Overall Height : 29.50 mm Bore Size : 5.99 mm Racing or Non-racing : Racing STD or customs size : STD with cutback added Trailing Angle : 45 Degree Blade : 6+6 Bore Type : Through Fits OE Comp Hsg : Fit OE Comp Hsg Cutback : 6.0 Rotation : Forward Link to comment https://www.sau.com.au/forums/topic/471347-which-should-i-go-with-gtx2863-2530-or-2860-5/page/10/#findComment-7862772 Share on other sites More sharing options...
frakzz Posted December 18, 2017 Share Posted December 18, 2017 9 hours ago, Dose Pipe Sutututu said: Good luck, looks as much of a fail as trying to fit 1/2 height injectors with 3/4 height extensions to a R34 NEO intake manifold. Suitable for Turbo/Chra or Upgrade for 739548/446179-0066 Link to comment https://www.sau.com.au/forums/topic/471347-which-should-i-go-with-gtx2863-2530-or-2860-5/page/10/#findComment-7862773 Share on other sites More sharing options...
R_34 Posted December 18, 2017 Share Posted December 18, 2017 Well that's equivalent to a gtx2863 compressor wheel but in 6+6 blades instead of 11+0. 2863 wheel mated to gt2510 turbine has already been tested and proven to be a fail. I can't recall if you're on gt28 or gt25 turbine but either way that's too much compressor flow for a stock housing gtr turbo IMHO. 2 Link to comment https://www.sau.com.au/forums/topic/471347-which-should-i-go-with-gtx2863-2530-or-2860-5/page/10/#findComment-7862774 Share on other sites More sharing options...
frakzz Posted December 19, 2017 Share Posted December 19, 2017 (edited) I have hks 2530 47.7-60, .60 GTX2863 more diameter, more difficult to untwist, in addition, the weight at the ends of the wheel at 2863 more, which at 300,000 rpm becomes a big difference GTX2863 weigh 63g, and the GTX2860 56g, these wheels weigh only 47g, the stock weighs 50g However, I am thinking about putting a turbine house .72 instead of .64 Edited December 19, 2017 by frakzz Link to comment https://www.sau.com.au/forums/topic/471347-which-should-i-go-with-gtx2863-2530-or-2860-5/page/10/#findComment-7862835 Share on other sites More sharing options...
R_34 Posted December 19, 2017 Share Posted December 19, 2017 Weight of the wheel doesn't influence the rpm you see full boost. Wheel aero, balance between compressor and turbine capacity/diameter and turbine housing are the main factors.Weight of the compressor wheel somewhat matters during transient (between gear shift or when you floor it above boost threshold for example). But weight is nothing really, it is how it's distributed around the axis of revolution ie inertia that is important.And while your new wheels are lighter they're also bigger in diameter. The weight is further away from the axis and distance account as squared when you calculate the inertia. So weight means almost nothing for transient. Especially when the turbine is more than twice the weight.For the record these wheels will not hold themselves at 300k rpm. They may spin up to 165k rpm but that's about it.Fitting bigger wheel in stock housing will just net you more lag for marginally better power if any.Going bigger exhaust housing should help you unveil that theoretical power that these wheels may flow but it will add another bunch of lag.For the money you'll spend fitting these wheels and sourcing .72 a/r exhaust housing you could get a good single outspooling/outflowing and with way better transient than what you're building.If you want more response with a 26 with stock-ish twins you should stroke the engine, install a variable valve timing (hks one or made one yourself as I did on my 20), go single turbo or do the three solutions I mentioned.If you just want more power this is the same recipe except for the variable valve timing.But that's your car, your money, your life. There is just a consensus here that tells you that it is a terrible idea that has been tested before albeit with smaller gt25 turbine (hks gt2530 comes with the gt28 turbine). 1 Link to comment https://www.sau.com.au/forums/topic/471347-which-should-i-go-with-gtx2863-2530-or-2860-5/page/10/#findComment-7862843 Share on other sites More sharing options...
frakzz Posted December 28, 2017 Share Posted December 28, 2017 (edited) Now the car is going very well, but there is a turbojam at the switchings. I want to fix this and get 600 + bhp. Unfortunately, forged wheels from 2860-5s do not make. Who can help to choose the best wheels? Attached file with list of wheels Billet Compressor Wheel.xls Edited December 28, 2017 by frakzz Link to comment https://www.sau.com.au/forums/topic/471347-which-should-i-go-with-gtx2863-2530-or-2860-5/page/10/#findComment-7863530 Share on other sites More sharing options...
r32-25t Posted December 28, 2017 Share Posted December 28, 2017 Put a single on it cause you’re fighting a losing battle here 1 Link to comment https://www.sau.com.au/forums/topic/471347-which-should-i-go-with-gtx2863-2530-or-2860-5/page/10/#findComment-7863531 Share on other sites More sharing options...
Mick_o Posted December 28, 2017 Share Posted December 28, 2017 (edited) Frakzz just give up on the twins mate you're wasting your money and time. Put 1 turbo on it that will meet your goals it will make the power it will be far more responsive and make for a more reliable healthy engine if you choose an appropriate sized turbine housing. Chase your tail on every possible wheel combination possible THEY WILL ALL FAIL! Why not just spend that money on a nice single so you dont have to keep pulling turbos on and off and paying to have them machined, retuning and dyno time etc. Its gunna be more fun to drive, will actually be running instead of living on a hoist & did i mention will be more responsive?? JOB DONE! Edited December 28, 2017 by Mick_o 1 Link to comment https://www.sau.com.au/forums/topic/471347-which-should-i-go-with-gtx2863-2530-or-2860-5/page/10/#findComment-7863532 Share on other sites More sharing options...
Mick_o Posted December 28, 2017 Share Posted December 28, 2017 Just realized its taking almost 2 seconds to come onto target boost pressure between gears.... Thats TERRIBLE! I dont wanna be sounding like a complete cock here. But i do appreciate the effort you are going to and sharing all your data. These are the things that help people make informed decisions about setting their cars up. But i think you need to look at your data and how many times you have fallen short of your goals and cut your losses and bolt on a nice manifold and single and enjoy your car! Link to comment https://www.sau.com.au/forums/topic/471347-which-should-i-go-with-gtx2863-2530-or-2860-5/page/10/#findComment-7863533 Share on other sites More sharing options...
frakzz Posted December 28, 2017 Share Posted December 28, 2017 (edited) I will not give up )) How about this? https://conceptzperformance.com/czp-pro-boosted-garrett-gt2860r-bb-700-hp-billet-wheel-ball-bearing-twin-turbo-kit-nissan-300zx-90-96-z32-739548-5009s-kt_p_17163.php what about this wheel? Nose Dia. : 15.41 mm Inducer Dia. : 46.52 mm Exducer Dia. : 60.13 mm Extend Tapered Tip Exducer Dia. : No Extend Tip Tip Height : 6.16 mm Super Back Height : 2.30 mm Overall Height : 24.50 mm Bore Size : 5.99 mm Racing or Non-racing : Non-Racing STD or customs size : STD size Trailing Angle : 45 Degree Blade : 6+6 Bore Type : Through Fits OE Comp Hsg : Fit OE Comp Hsg Cutback : 0.0 Rotation : Forward Edited December 28, 2017 by frakzz Link to comment https://www.sau.com.au/forums/topic/471347-which-should-i-go-with-gtx2863-2530-or-2860-5/page/10/#findComment-7863546 Share on other sites More sharing options...
Mick_o Posted December 28, 2017 Share Posted December 28, 2017 You must have lots of money to burn? How many attemts will you have? You wont find a combination that works because there quite simply isn't one! Link to comment https://www.sau.com.au/forums/topic/471347-which-should-i-go-with-gtx2863-2530-or-2860-5/page/10/#findComment-7863556 Share on other sites More sharing options...
GTSBoy Posted December 28, 2017 Share Posted December 28, 2017 I'm laughing my arse off right here. 2 Link to comment https://www.sau.com.au/forums/topic/471347-which-should-i-go-with-gtx2863-2530-or-2860-5/page/10/#findComment-7863559 Share on other sites More sharing options...
r32-25t Posted December 28, 2017 Share Posted December 28, 2017 Just jamming a bunch of different compressor wheels in isnt going to fix your problem, you need to look at everything as a package. Start also looking at your housing sizes and turbine wheel sizes or just put a single on where someone else has done all the work for you Link to comment https://www.sau.com.au/forums/topic/471347-which-should-i-go-with-gtx2863-2530-or-2860-5/page/10/#findComment-7863562 Share on other sites More sharing options...
Meathead Posted December 29, 2017 Share Posted December 29, 2017 2 Link to comment https://www.sau.com.au/forums/topic/471347-which-should-i-go-with-gtx2863-2530-or-2860-5/page/10/#findComment-7863564 Share on other sites More sharing options...
Dose Pipe Sutututu Posted December 29, 2017 Share Posted December 29, 2017 Gay, waste of time and money Link to comment https://www.sau.com.au/forums/topic/471347-which-should-i-go-with-gtx2863-2530-or-2860-5/page/10/#findComment-7863566 Share on other sites More sharing options...
frakzz Posted December 29, 2017 Share Posted December 29, 2017 9 hours ago, Mick_o said: You must have lots of money to burn? How many attemts will you have? You wont find a combination that works because there quite simply isn't one! I can always put the wheels from 5s and it will definitely work. They are simply cast wheels, but they want billet. Link to comment https://www.sau.com.au/forums/topic/471347-which-should-i-go-with-gtx2863-2530-or-2860-5/page/10/#findComment-7863589 Share on other sites More sharing options...
Robzilla32 Posted December 29, 2017 Share Posted December 29, 2017 Edited: Oops wrong message. Link to comment https://www.sau.com.au/forums/topic/471347-which-should-i-go-with-gtx2863-2530-or-2860-5/page/10/#findComment-7863590 Share on other sites More sharing options...
Mick_o Posted December 29, 2017 Share Posted December 29, 2017 21 minutes ago, frakzz said: I can always put the wheels from 5s and it will definitely work. They are simply cast wheels, but they want billet. So just bolt a set of 5s on mate and be done with it?? Whats the attraction of billet? As has been said numerous times there is not enough turbine to drive a billet wheel efficiently. But dont expect them or any twin turbo setup to last long with 600hp as you will simply cook them running them WAAAY out of their efficiency range. Link to comment https://www.sau.com.au/forums/topic/471347-which-should-i-go-with-gtx2863-2530-or-2860-5/page/10/#findComment-7863591 Share on other sites More sharing options...
Piggaz Posted December 29, 2017 Share Posted December 29, 2017 23 hours ago, frakzz said: Now the car is going very well, but there is a turbojam at the switchings. I want to fix this and get 600 + bhp. Unfortunately, forged wheels from 2860-5s do not make. Who can help to choose the best wheels? Attached file with list of wheels https://www.sau.com.au/forums/topic/445007-the-frankinstien-twin-turbo-thread/ I found this. Might give you a whole heap of new idea’s for your frankenfails. Make sure you give a failure % too. Carry on. ? Link to comment https://www.sau.com.au/forums/topic/471347-which-should-i-go-with-gtx2863-2530-or-2860-5/page/10/#findComment-7863592 Share on other sites More sharing options...
frakzz Posted December 29, 2017 Share Posted December 29, 2017 (edited) what role does Trailing Angle play? 45/60 CZP Pro-Boosted Garrett GT2860R BB 700+ HP Billet Wheel used this wheels Nose OD: 11.82 mm Inducer Dia.: 49.62 mm Exducer Dia. : 61.98 mm Extend Tapered Tip Exducerdia : 65.90 mm Tip Height : 4.95 mm Super Back Height : 2.32 mm Overall Height : 27.63 mm Bore: 5.99 mm Bore Type : Through Blade : 6+6 Rotation: Forward Edited December 29, 2017 by frakzz Link to comment https://www.sau.com.au/forums/topic/471347-which-should-i-go-with-gtx2863-2530-or-2860-5/page/10/#findComment-7863598 Share on other sites More sharing options...
