1 hour ago, Robzilla32 said:
This thread used to be interesting but now it's dull. Can someone chuck some turbo(s) in a car already and report back (preferably with skid vids)
Or run some laggy twins and blow the 2nd turbo
46 minutes ago, acsplit said:
3 hours ago, Super Drager said:
Call hypergear... pay him x amount of dorrah... say you want x amount of hp. Recieve turbos... install.. post result
Nah don't do that. Plenty of good turbos on the market
Of course like GT-RS turbos. Comes on at 5700rpm and quickly shift before you
1. Smash the limiter because you have a "great" powerband OR
2.shift too slowly and fall off boost.
Amazing :)
  • Confused 1
On 1/12/2018 at 5:50 PM, frakzz said:
What is the difference in the number of blades in the turbine wheel? 9,10,11?
To answer your question, it will slightly change the efficiency of it. Depends on the design. What it won't do is make it a multiple times better, eg 11 blades isn't 10% more flow than 10. Remember the more blades you have the more volume inside the compressor is blade. Doesn't help.
Flow is still a function of area and a number of other factors so number of blades is only going to have an smalll change in the characteristics of the compressor. Realistically an optimum design is going to take account of the operation parameters, the housing size and shape as well as the blade design. because garrett or whoever uses x blades in y new design, doesn't mean that x blades will be better in an older, different, compressor.
what wheels should I try?)))
these will definitely work
Inducer Dia. : 46.52 mm
Exducer Dia. : 60.13 mm
Extend Tapered Tip Exducer Dia. : No Extend Tip
Overall Height : 24.50 mm
Trailing Angle : 45 Degree
Blade : 6+6
Inducer Dia. : 47.10 mm
Extend Tapered Tip Exducer Dia. : 64.98 mm
Overall Height : 29.50 mm
Blade : 6+6
Inducer Dia.: 49.62 mm
Exducer Dia. : 61.98 mm
Extend Tapered Tip Exducerdia : 65.90 mm
Overall Height : 27.63 mm
Trailing Angle : 60 Degree
Blade : 6+6
You need to use only one wheel with an inducer of 62.6mm and an exducer of 83mm mated to a turbine with a 74mm inducer. Preferably in a twinscroll housing.
I can't be more specific as I don't have all the details on these wheels but they seems to perform very well on RB26.
  • Like 2
I dont know why you are asking? You haven't listened to anything anyone has said all along ?
If they are gunna work use them and post your next failed result!
I will say this AGAIN.... NONE OF THIS SHIT WILL WORK! So just get over it and buy a single!
  • Haha 1
I like the way you think! ?
Starts with E and ends in R
Blade : 6+6
Blade : 6+6
Blade : 6+6
No one knows what will work as you are in uncharted territory, you’ll have to just be the test subject
You're a twins guy maybe you should offer him some advice? Pretty sure you've thrown some Frankenfail ideas around here before? What would you recommend he tries next?
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
