Or do what the Japs did, run dual plenums, dual ICs.
That should help reduce the turbos "fighting" each other.
It's just like when you see two cocks in one box.. doesn't work too well, you need one in the pink and the other in the stink so noone is fighting for it.
My stance has been 1x hole 1x goal, ie single turbo!
  • Haha 1
I have no idea what those numbers mean.
The path ot successfully running twins has been shown numerous times.
Have a sensible power goal, mild cams at the most, Twin Turbo pipe divider mod, good dumps/front pipe combo and don't use -5s if you value response.
-9s with all of those bits will get you a healthy figure for the street.
If you need the better high end power of -5s on a 2.6L and still want response, put a twin scroll single on it.
What is your power goal?
Was going to say i get more boost sooner with my EFR but its got .2L and 260x11 cams behind it.
Glad i didnt install these on mine now. Will be interested seeing how old mate whos got them goes using the stock port shrouded front covers.
Bet ya glad ya listened now Pete? Twins in the bin single for the win ?
Wouldn't matter what cams or capacity the EFR still woulda knocked the snot out of those frankenfart twins.
At ANY power level!
Edited by Mick_o
On 22.10.2017 at 5:29 AM, Roy said:
So what turbine is your rebuilt turbos running? Still the 2510 turbine or full GTX2863 core in HKS housings?
full GTX2860 core in HKS housings
If you're serious then you're going to need a very good single turbo, like an EFR, with proper twin scroll setup.
The only way you're getting that goal with twins is with a huge displacement increase.
The single turbo swap will be cheaper.
You're also going to want a few other mods so it can live for more than a few Dyno runs.
When are -5s spooling? Can I get 600whp from them?
Edited by frakzz
11 hours ago, Piggaz said:
Is there a reason why you need to stay twins? Personal reason? Law enforcement? Because that's how Nissan wanted it? GTR's "must" have twins?
he was like Paul Version 1.0, twins, lag was life. Paul Version 2.0 is about usable power, better heat management and less homosexuality.
  • Like 1
made a lot of things to make it convenient to service turbines
Edited by frakzz
5s are f**ken shit! So are journal bearing turbos.
As above 8374 is an absolute beast of a turbo!
If you want good power and response forget the twins!
If you need the stock look so you dont get busted sure stay twins. But thats the ONLY reason to keep them!
21 minutes ago, Dose Pipe Sutututu said:
A journal bearing twin scroll single turbo, I would dare say would perform better than a set of twins that produce like for like power output.
100% ?
Will only suck a dick between gears not everywhere like the 5s do!
Edited by Mick_o
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
