Wanted: R32 Gtr
Hi all,
I'm looking for an R32 Gtr, been looking for a good while now and only keep seeing rust buckets and cars that are just rubbish condition regardless of price and what the seller talks about the car.
I either want a modified with a built engine already or a stock standard one with no mods or minor like exhaust etc.
Preferably in grey, black, silver or blue.
I hope someone on here knows of any for sale in any region of Australia but in good condition, no rust and doesn't smell like smoke which I have seen a lot of also.
Edited by Zilla_Gtr
Updated information, added region
https://www.sau.com.au/forums/topic/471356-wanted-r32-gtr/
Good luck Zilla, I was looking for a little while, all I can say is check every forum you can. There is more then just car sales. I also emailed/messaged CRD, Racepace and JEM asking if any customers were thinking of selling. Something will come up, you just have to be persistent. Looking for the right car took over my life, my wife was getting the shits with me and I was on the verge of giving up when I found my car. Right now couldn't be happier, it was well worth the hunt. Just make sure you get the right car for you, don't settle.
I also have to say had help from friends and a new friend/member from here, Steve, he helped me a lot through my search gave me slot of information, thank you Steve, I owe you a beer, next year at the GTR festival.
Anyway good luck and if you need any help or my opinion on a car, pm me.
Cheers
  • Like 1
https://www.sau.com.au/forums/topic/471356-wanted-r32-gtr/#findComment-7841350
Hi Zilla,
For the right price, I'll sell mine (~50k or thereabouts):
16107199_10154301860437358_7453806377926729462_o.thumb.jpg.04e87b6ad7da17260555e58011880c39.jpg
1992 R32 GT-R, 130,000kms on chassis, 5,000 on engine. 530kW @ 35psi on United E85 and 450kW @ 24psi.
Engine:
- R34 GTR bottom end, completely stripped
- Block acid dipped, cleaned, bored & honed
- Standard R34 GTR crank (30,000 km) and rotating assembly balanced
- ACL Race bearings
- ARP main studs
- ARP head studs
- Nitto oil pump
- Ross forged pistons
- N1 water pump
- Ross 1000hp harmonic balancer
- Tomei cam gears in/ex
- Tomei Poncam 260 deg 9.15 lift in/ex
- R34 GTR head (30,000 km), refreshed with:
    - New valve stem seals
    - Bronze valve guides
    - Brian Crower dual springs
    - Brian Crower titanium retainers
- Tomei metal head gasket (1.3mm)
- Tomei oil pan baffle kit
- Autech catch can
- ARC grill oil cooler
- HKS fuel rail
- Splitfire coilpacks
- 6x Bosch 2200cc injectors
- -8 TEFLON braided fuel line from external pump to rail
- Holley Dominator 1800 external fuel pump
- Walbro 460lph in tank fuel pump
- 3L surge tank
- Braided lines in engine bay
- Turbosmart FPR1200 fuel pressure regulator
- Koyorad radiator
- Nismo low temp thermostat
- TRUST 100mm drag intercooler
- 6boost T4 twinscroll exhaust manifold
- Precision 6466 Gen 2 turbo (1.00 twin scroll, v-band rear housing)
- Turbosmart Powergate 60mm
- Custom fab work for all intercooler piping (stainless steel), intake piping (K&N pod)
- Custom fab 4" dump pipe into 4" stainless steel exhaust (2x Magnaflow oval mufflers)
- Adaptronic ECU
- GReddy Profec OLED boost controller
Suspension/Brakes/Wheels:
- TEIN Super Street coilovers (5000km old)
- R34 GTR Brembos front & rear
- Project Mu 330mm front & rear
- Project Mu brake pads front & rear
- 18 x 9 +20 BBS LM wrapped in 5000km old Yokohama ADVAN AD08R tyres (265/35/18)
- HICAS locking bar
Driveline:
- Rebuilt R32 GTR standard gearbox (refreshed with OEM Nissan parts 5000km ago)
- Exedy twin plate clutch
Interior, Exterior & Accessories
- R33 GTR seats in front
- Nismo 320kph speedo from factory
- Momo steering wheel
- N1 headlights
- Genuine N1 3 piece sideskirts & rear spats
- Genuine N1 front bumper
- Full professional MNP1 respray.
- HKS Kansai Service strut tower bar
- Brand new seals all round
- Have original head unit
- Rockford Fosgate speaker system front + back with Alpine single DIN head unit
I am located in WA, though.
Cheers.
Edited by Uncustom
  • Like 2
https://www.sau.com.au/forums/topic/471356-wanted-r32-gtr/#findComment-7841370
Cheers
Thanks old man gtr,
yeah mate it does take persistence that's for sure, still searching though.
Edited by Zilla_Gtr
https://www.sau.com.au/forums/topic/471356-wanted-r32-gtr/#findComment-7842221
I'm still searching and will give up soon enough.
if it is a built R32 It must have all receipts of the build no exceptions.
if it is a standard R32 it must have the standard 180kph dash and in good condition all round.
preferably Japanese import papers, de-reg and auction report ( although some don't have paperwork ).
I would like a built one as mentioned but I don't mind a standard as I would have it built properly.
Highest regards
https://www.sau.com.au/forums/topic/471356-wanted-r32-gtr/#findComment-7842224
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
