The correct brake rotors/pads for WGNC34 Series 1/1.5 RB25 non turbo
Hi all,
TL;DR for all you people who cbf reading lol
Front rotor (Partstop) - DBA914 - Maxima A32/G30
Diameter: 280MM
Thickness: 26/24MM
Rear rotor (Partstop) - DBA11003 - R32 (Probably 20e 4dr)
Diameter: 267MM
Thickness: 16/14MM?
Front pads (Repco) - D81305RCT
Rear pads (Repco) - D81144RCT
There isn't much info on 25DE Neo 4WD stageas as you aussies don't get them, but here across the ditch in NZ we do. So I super struggled with what rotors to get.
So i've gone to get new rotors (front and rear). The rears they couldn't help me at all and said they would call a supplier and get back to me. I have a 1998 25DE Series 1.5 stagea. As you do, you go to repco, I gave them my rego, they searched up the car and bought up all of the listings for the DE 4WD and I made sure it was the correct one, they said yup and gave me all the different rotors (all the same in size). The rotor they ended up giving me was a S14 200SX Turbo/300ZX Twin Turbo rotor, I didn't notice what it was for until I tried to fit the caliper over and then looked at the box. So I went back the following day and they confirmed that it was correct for stagea, the only thing I can think of now that could have been the issue is that because mine is a 1998 where they had both S1 and S2 released it was bringing up S2 listings which have bigger brakes at the front (for turbo 4WD anyway) It makes me wonder whether if I suggested a 1996/1997 model it would give the correct rotor size.. almost makes me want to go in and find out.
IMG_0239.thumb.JPG.5eab9aa58bf17ac5be3b0fedb85b7552.JPGIMG_0250.thumb.JPG.f9cee2c0fe7bfe634a15d6181c85bbe3.JPGIMG_0246.thumb.JPG.f3b2fa6effcb825dcae71410284a3e15.JPGIMG_0233.thumb.JPG.ba7908748ec767608f2d594f2bcf892d.JPGIMG_0242.thumb.JPG.d0243226f2f78cc5137f554894a3d107.JPG
Here is the difference between the incorrect rotor and my old rotor, you can see the height is onl off by 4 or so MM.
So I returned the incorrect rotors and got my money back, they were roughly $250 on sale (30% off). Repco provided me with the correct part number DBA914, but they had none in stock. I cant remember how we got to that part number but other than that they couldn't help me any more than that. Although they did have slotted ones at $450 a pair (I obviously declined lol). They then suggested going to Autostop with that part number, luckily Autostop had both in stock for $54.10 each. I then tried my luck and asked if they had rear rotors and to my disbelief they had some that was listed for the stagea
and yes, yes they fitted :D
For the fronts, its super easy, i'm sure if you are looking for the parts yourself then you will most likely be doing the brakes so you probably already know how, but, if you dont I highly suggest watching ChrisFix video here on how to do your brakes.  The incorrect rotors repco gave me was 30/28, thus being too thick for the caliper and new pads to fit over. Every other dimension was fine, just the thickness was incorrect. The new front rotors fit on perfectly, but the front right was making a clunking noise when I let off the brake pedal, this went away after probably 5 quick brakes.
IMG_0259.thumb.JPG.4344e67cedc0c35759d8ffe41054b066.JPGIMG_0264.thumb.JPG.056364f25426496cd13afb740cfda789.JPG
Doing the rear brakes is exactly the same as the front. Just make sure that your hand brake is off and the car wont be able to move before you go trying to hit off the old rotor and could potentially damage the drum brake. If you're lucky like I was, you may have screw holes where you can screw a screw in which helps remove the rotor if its rusted on like mine were lol. The new rear rotors do NOT have these screw holes, but the fronts DO.
IMG_0288.thumb.JPG.738cfaa31f5e6bbd0f9f691a821ab5dc.JPGIMG_0291.thumb.JPG.88ce7663f024e27c43c69212e5a5e4cc.JPGIMG_0295.thumb.JPG.34806a1d79f9626df47ced5506ae7bd8.JPG
Had the same weird clunking sound coming from the rear right after fitting the new rotors and pads (could have been left as well for front and rear times) but from the drivers seat with the window down it sounded rear right, so while I still had the car in reverse I just went on the brakes/off the brakes about 10 times again and the clunking sound stopped, it did get quiter the more I did it too. So I'm not too sure whats causing that to be honest.  I'm unsure of the thickness on the rear rotors, but by the looks of it, if you're asking for this rotor its gonna fit.
Right, so, you should be careful when you're going to Repco looking for brake rotors as they don't have correct listings (for me anyway) But if you want 100% certainty go to Partstop as they have both rear and front rotors.
So, here are the parts that worked for my stagea.
These are also just your standard rotors, not slotted or drilled.
Diameter: 280MM
Thickness: 26/24MM
Diameter: 267MM
Thickness: 16/14MM?
Rear pads (Repco) - D1144RCT
So hopefully if you're looking this post will pop up and these will be correct for you and save all the hassle of getting wrong items!
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
    • Here is picture of the rear brackets again seeming to have eating itself or corrode or whatever. Can’t describe it , hope someone could explain this
    • No i am in the uk so maybe road salt etc but checked rear and same story where handbrake cable seems to have eaten part of the bracket. Have emailed alpha omega waiting for reply
    • I've not looked at a GTR without the booster there. Is the hole and mount on the firewall not just the same as GTSt? I would have expected it to be. Nissan don't change panel stampings if they don't have to, and you'd think they'd just order/design the booster to mount to the same place.
    • They have all sorts of "failure" modes. When they are brand new, the can either be very very tight, or reasonably mobile. If they are reasonably mobile, you'll probably have a good start. If they are very tight, then they can catch/grab at every little motion, and they mark the ball or the outer race, tearing off whatever teflon lining is in the outer race, then they can rapidly degenerate from there. If they get wet, they can just rust. They are just steel and will turn red pretty quickly. Water can get in behind them and sit and cause them to become crunchy and then proceed to tear themselves up, as above. Same with grit and dirt. Manufacturers and OEMs of the arms that use them will tell you that because they are teflon lined (well, the good ones, anyway), you shouldn't grease them. If you do grease them, then the grease will catch any passing grit and dirt and hold it in place where it can cause damage. Race teams that have them will lubricate them thoroughly. They will also inspect them every 5 minutes and replace them every 10 minutes, if need be. Some manufacturers of arms will provide dust boots. These can help, but they are seldom perfect, and sometime just make the situation worse, being a place where crap can collect. I have made nappies for some of mine with PVC sheet and race tape, to try to minimise the access of crap. When they wear, you can get a tiny tiny amount of movement between the ball and the outer race. This will make clicking noises. It will also make the arm have "slop" in that the tiny amount of movement available at the inner end of an arm can cause a lot of movement out at the outer end. 0.05mm at 5mm from the pivot becomes 4mm 400mm away from the pivot. If they are too tight and binding, they impede the proper motion of the suspension arm and put loads into it and the rest of the suspension that are not supposed to be there, and can cause failure. Think broken welds, broken threaded sections on the adjustable parts, mounts ripped off the chassis, etc. All of these are possible, which is the main reason why they are essentially illegal on the road in Australia.
