Installation of Child's Car Seat into R33 GTR
How to install a child's car seat into your R33.
***Firstly, let me say, if you don't understand what you're doing or what might effect the installation of child seat, please seek expert advice (no this nor any other internet article counts). If you crash and the car seat is not fitted to your vehicle correctly it may not be safe for you or your child. I take no responsibility for the well-being of your child or your installation quality.
This DIY document is for a non ISO-FIX seat only.
Step 1: Remove the back seat (both the bottom and back cushions). Please see the attached links.
Step 2: With the seat out you should have a clear view to the boot of the car.
This is the passenger side of the back seat (as opposed to behind the driver).
Step 3:
With your child seat, you should have purchased a bolt and anchor for the strap. (if its a new seat it should be included).
The anchor holds the straps for the seat and the bolt holds the anchor to the car. It is important that you understand where the forces will be applied in an accident as this anchor holds your seat (and child) in an upright position.
The Anchor should be bolted at close to the middle of the rear passenger seat as possible to remove any chance of the seat swinging left or right when the car is moving. Select a suitable place for the bolt to be placed.
I chose this position:
The bolt location was as close to the centre of the rear passenger position as I could make it. This should mean that the straps are almost exactly straight (which is preferable).
Step 4:
Mount the bolt to the car. Keep in mind the forces of an accident will most likely be rear to front (imagine not stopping your car in time and rear ending someone). That is the seat will need more help staying in position for the forces trying to push it forward toward the engine of the car than it will being pushed back into the boot.
With this detail in mind i placed the large oversized washer in the boot section of the car.
Please note the over-sized gold washer is not visible in this picture.
Step 5:
Place the child seat in the car and connect the straps (without twisting the straps) to the anchor. The child sear should be in the car before the Skyline seat cushions are put back into the car.
It should look somewhat like this by now:
Step 6:
Reinstall the rear seats (please see the link above). The rear cushion should be slid under the straps so that the straps run over the top of the cushion.
THIS IS VERY IMPORTANT. The straps must attempt to push the rear cushion down in an accident or high force. If they run under the rear cushion the straps may dislodge the rear cushion and it may end up loose in the car (ie, flying out the front).
Step 7:
With the car seat in refer back to your installation instructions for your seat. Follow them exactly and make sure the seat is completely secure before placing your little one in the seat.
Here's the instructions for mine:
https://www.britax.com.au/service-support/instructional-videos-and-user-manuals/?id=17599
There's also a video: https://www.youtube.com/watch?v=ftDugB3n058
If you are in any doubt at this point, contact one of the car seat installers and get their assistance. (They are cheap as anything as well, I think $30 is pretty standard).
Step 8:
With the child seat installed and the rear seat cushions back in place, you should test fit the child and make sure it is secure before you drive anywhere.
After that. Enjoy having your little one in the car with you. :)
*Also consider investing in beanies with ears... they make children adorable.
  • Like 1
It is worth saying that every car should have had child seat anchors installed when it was complied before first registration. Sadly a lot of workshops seem to skip that step
Yeah but do they have to drill through the speaker cover and install the mount so the rear speakers are ruined?
Not if they complete it like this. Which I should think is the best way.
It utilised an existing bolt hole and requires nothing more than a socket set.
Props to you my man, that's some good stuff. Your daughter's hat is awesome btw.
I'd never bother doing this in my skyline because no way I'd ever drive my kid in a car with no airbags lol. Not that I have a kid or want one, but that's besides the point.
Cheers!
  • Like 1
@drunken0elf, i hear you, but if I can't take my daughter with me, this car would go almost completely unused, that doesn't seem right!
@niZmO_Man I think you are spot on here. A child in their correctly fitted car seat are probably safer than the other occupants. Of course, a mid-90s GTR will crumple like a soda can given the opportunity, so I think it would be best not to crash... This is certainly my plan. :D I drive it quite sedately with her on board and anyone else really. When its just me, sure, then some fun can be had!
Oops, forgot to mention in my r32.
I thought the R33 had airbags? Not judging you lol, I genuingly believed the r33 had airbag.
But now that I think about it, you do have a solid point that she would be the safest in such an event. *touches wood** let's all make sure it doesn't happen tho.
  • Like 1
@drunken0elf, my car has a driver and passenger airbag (I might have to check the passenger). It certainly doesn't have curtain or knee bags in the back like our family wagon!
Yeah car seats are pretty good for kids. I just wish Australia would wake the f**k up regarding ISO-Fix. Way safer/better according to crash tests...
All good on the judgement side, the plan here; don't crash the car!
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
