Lowering a r33 gts-4
Hi, just after some advice in how low you can lower a gts-4 or gtr without effecting the camber or geometry of the awd and suspension. The car is going to be street driven so nothing crazy low and still legal limit from the ground. But Would anyone know how low you can go on standard camber adjutsment and control arms ?
https://www.sau.com.au/forums/topic/471396-lowering-a-r33-gts-4/
The usually accepted number is the same, both for legality reasons and also how well the suspension works.  This is an "eyebrow height" of around 340-345mm.  The eyebrow height is defined as the vertical distance from the centre of the wheel hub (actually the centre of the wheel's own centre cap will do) to the height of the standard wheel arch/guard lip.  Actually measuring it on the slight outward angle that is likely to result from the wheel sitting slightly inside the line of the guard is not really a problem.  No worse than the measurement error of eyeballing a tape measure anyway.
 alright good thanks for the reply so if i stay over 350mm from the top of the guard to the centre of the hub, I shouldnt need to get adjustable conrtol arms and camber kits, just a aliment will do ??
I wouldn't say that you wouldn't need adjustable somethings.  That depends on the physical state of your existing bushes, how bent parts of the car are, etc etc.  Also, at or near that minimum height, you will possibly end up with more -ve camber than you'd like, particularly at the rear.  So some Whiteline kits installed in the rear uppers might make a lot of sense. There pretty much is no camber adjustment in the stock suspension.
I personally would not try to avoid putting in at least adjustable poly bushes in the front uppers and rear uppers, adjustable front caster rods with rod end (rose) joints, and possibly one or two other things.  Having the ability to wind in a little more camber at the front or a little less, plus change the caster can make a massive difference to how the car drives, tyres last, etc etc.
I would get them if i could afford them but i just brought bc coilovers for it and cant spend a heap of money right now, i only plan on having the car 360mm eyebrow height, i dont mind gettibg adjustable bushings for it but trying to avoid getting new caster and upper control arms
Thanks for the advice appricate it
Edited by Rewseyracing
I just checked the official pdf from SA Transport for the eyebrow heights.  R32&3 turbos are F345, R355.  All R34s are F340, R345.  R32&3GTR are F375, R355.
These are all with the vehicle in operating condition, but unladen.  So, no load in the boot, no passengers.
360 will be fine.  But keep in mind that 360 F&R might look a little wrong.
The 100mm clearance under the car and the 2/3s original suspension travel requirements are also in play but you should not have a problem at the acceptable eyebrow heights unless your exhaust hangs low or you have an extra CF lip on the front.
Thanks for all the help ill defently make sure the exhaust and everything else is above 100mm and hopefully have the front at 360-370mm and rear at 350-355mm. Ill still get the adjustable upper control arm bushes and rear bushes just to make sure the tyre wear is going to be happy
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
