Helmet + Hans Packages
Been looking at Hans devices as I'm driving more aggressively, run a half cage, fixed back seat, and harness. I do use a little neck support donut, but after seeing crash test footage about how the head just moves forward while everything else stays put, a HANS makes a lot of sense.
My current helmet is just a Sparx basic rthing, not HANS compatible so I'd need a new helmet and ebay is running various deals at the moment.
This can be had for $850ish delivered.
http://www.ebay.com.au/itm/131954318581?ssPageName=STRK%3AMEBIDX%3AIT&fromMakeTrack=true
Anyone got experience with Racelid helmets or that particular HANS model?
I'm also not sure which model in terms of degrees, I can measure this, but any advice on that front is appreciated.
https://www.sau.com.au/forums/topic/471397-helmet-hans-packages/
I've also been thinking that I should have a Hans device & helmet to suit, for the same reasons. I haven't done any research, but your post will prompt me to. I think I'd prefer an open face helmet for in the car - have been using my bike Shoei to date. I usually leave the visor off.
Having bought too many bike helmets in my lifetime, I do know that I need to try them on before committing - the same size in different brands fit differently. I can only assume that car helmets are the same.
I did buy some suspension bits from that Ebay seller last week, and had no issues - they were as described, packed well & arrived in a couple of days.
I have that model racelid minus the duck bill. Fairly decent. I found the visor lock tabs to be a bit poorly designed. Tinted/colour visor options are also limited.
Definately go try them on though. I had a bit of trouble finding a comfortable car helmet before getting this.
No experience with HANS though
Personally I wouldn't buy a helmet I couldn't try on. Proper fit matters for comfort and safety.
I stuck with a basic bike helmet for years until the category required us to have HANS. I didn't want to move to one due to cost and an (incorrect) perception that it would be uncomfortable and restrictive.  Of course you also need a 4+ point harness, and make sure that the width of your HANS shoulders are the same width as your belts, they often are not.
  • Like 1
I have 4pt Velo harness, 72mm strap which is just under 3".
I'll check the Hans.
I'll ask the local kart and bike shops, my best guess isni could maybe try a Bell helmet.
I've got a young family and I'm driving harder now, making mistakes, sideways, offs etc so I just want that security.
Also either add on to or replace the cage, it's one of Brad's (ProFab) bolt in, welded half cage.
Yes and no.
YouTube the clip of the rally driver who puts his car into a ditch at low speed and almost knocks himself out (I will post tomorrow if you can't find it).
His nav had a Hans on, no issues for him/her.
You also hit the nail on the head. I would like to do either/and PI, EC/Bathurst either in the Silvia or the GTR.
As mentioned earlier, I have a family I'd like to come home to, and we're not talking big money in terms of "insurance".
Plus, have you seen how shitfully I drive :D
I spent double what you are looking to spend however im in open cockpit.
Just like with race suits the more you spend the better quality and more comfortable it gets.
Like Duncan said above, a helmet + suit are 2 things you just can't buy online... have to try on in person before paying for it as all brands/models/sizes are different.
All good points, I've seen enough cars end up in walls at my trackdays to be making this a priority.
Luckily Revolution Racegear have the same package for sale and there's one around the corner, hopefully it's in stock. Also thinking of going 6 point harness instead of the 4 point i currently have as tightening the shoulder straps hikes up the waist strap.
ah cool, they have the exact same kit for $879, much for muchness really, if they have it in store and fits well i'll support them. There's also a different closed faced for $829 and open faced option for $769
http://www.revolutionracegear.com.au/?PCID=10807&PSO=245&PSID=SPECIAL&PSV=Primary&CDO=
I have to drive past RRG in Adelaide this morning - I should get my arse in there and have a look.
  • Like 1
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
    • Reasonably hard, although I haven't run it with the new Endless setup yet. The old brakes were F50's on 335mm rotors and the car did a 1:40.6 at Phillip Island which is a reasonable time, I'm seeing high 600s on the temperature paint. A guy I know ran the Endless fluid at WTAC without issues and he was doing 1:33's I think (Evo) with a 355/332 setup. I don't get out to the track as much as I'd like but we put the car on the hoist and spanner check every bolt and re-paint mark everything, bleed the brakes, change the fuel, check the coolant system and re-bleed blah blah blah before every event. Motorsport is expensive, RB's are expensive so a couple of hours before an event is time well spent. It's also a net time saving because if you can keep your RB from self destructing it saves you time in the long term!
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
