Need Help On R33 Build!?
Alright so I just picked up a good condition gt2530 for 400$ recently that mates to the rb25det with that being said im looking for some 555cc injectors and a fuel rail to suit my car if anyone could give me links to what they use thad be much appreciated. Reason being is I have a raceworks fuel rail brand new and it says it takes 14mm top mount injectors but I have no idea what 14mm injectors to look for and havent seen anyone install a raceworks fuel rail into there car with photos! Also does that meen the top of the injectos are 14mm and the bottomg are 10 (assuming thats what stock injector sizes are)? Ive been thinking of going with BPP https://www.golebysparts.com.au/parts/view/284/58/nissan-rb20-25-26/fuel-rails-and-fuel-rail-injector-kits/rb25-r33-bpp-fuel-rail-and-bosch-1000cc-injector-kit but would a 255lph fuel pump be able to handle 1000cc injectors? second BPP is incredibly expensive for the price!
https://www.sau.com.au/forums/topic/471429-need-help-on-r33-build/
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
