Light throttle jerking issues
Hey guys, had my RB3025 neo tuned and runs great except for on very light throttle where it starts jerking.  I've had the tuner look at the low load points and says the pwr fc is old model and most likely the problem.  I'm gonna have a road tune done also to try find out more but can anyone suggest anything else that can cause jerking.
So some stairs of setup
2530neo, 3076, 44mm tial, z32 on 4inch pipe, gfb recirc BOV set soft, pwr fc, avcr, 1000cc experts, 416 walbro, stock reg,
One thought was I had to weld up the r33 throttle vacuum hole as it wasn't compatible with the neo mani.. not sure how important that is..
https://www.sau.com.au/forums/topic/471448-light-throttle-jerking-issues/
It's called "ACCELER." and the screen looks like this.. unfortunately it's upside down (got it off Google).
You will need a wideband and see what the AFR is like when you jab the throttle vs. RPM. Of course too rich will stumble, too lean will stumble.
Column 1 = RPM
Column 2 = how much fuel in ms
Column 3 = how long in ms
Because you're running larger injectors than stock, I would say reduce the amount in column 2 by the percentage of your injector size increase.
So OEM is 370cc right? now you have 1000cc or so.. that means you would only need 37% of the original throttle pump values.
Play around with it, however you will need a wideband.
  • Like 2
My MR2 turbo does this. When on light throttle it misfires.
I replaced just about all of the vacuum pipes. It's much better now but still not 100%. I still have the replace one pipe that comes into the cabin. Hopefully that sorts it.
  • 3 months later...
1 hour ago, Trex said:
Did you find a resolution to this? @AngryRB
The tuner had it a week for cold start and cruise adjustments and has improved alot, said it was running quite rich and needed new plugs.  It seems to go jerky after a bit of a flogging and not so much when normal driven.. Ive been told its likely the power fc and the injectors being so big. Be interesting to put a haltech in but cant justify the coin.
  • Like 1
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
