I know this question has probably been asked before, but im not too sure on how up to date the information might be, so i thought i would ask you guys as i have been dicked around so much i just want my car back :D
My 25 blew thanks to some dodgy actuator welding provided by a workshop which will remain nameless... Ive been told alot of things, but im relatively new to this whole car scene so i dont know what to believe...
What is the best option to go for in this situation? rebuild? drop in another 25? 26? conversion? and most importantly, who can i go and see that knows what they are talking about and can do quality workmanship at a reasonable price?? I just want my baby back on the road its been almost 2 months now :(
If anyone can give me some advice, and some sort of idea on what each option is going to cost, id appreciate it..
Thanks alot guys
https://www.sau.com.au/forums/topic/47145-the-final-word/
Go and see Ken at Hyperdrive - www.hyperdrivems.com.au. He is also forum member and alot of people go to him from the forums.
UNIT 1, 28 VALE STREET
MALAGA 6090
WESTERN AUSTRALIA
TEL: (08) 9209 3100
[email protected]
Or see Steve at SST
Unit 9/ 138 Radium St, Welshpool 6106 Ph(08) 9350 5444
https://www.sau.com.au/forums/topic/47145-the-final-word/#findComment-953400
sldfhlsajkhfljsdahlhsdalfhsadhfdsa
thx alot for ur input guys, geez we are talkin alot of money...
is there anything else i can do that might be cheaper? im not looking for mass hp or anything i just want my car back on the road. its not going to be a big racing machine.....
yeah im pretty sure the rings are gone....but the engine did seize mid cruise due to no oil. the actuator weld came off so no wastegate = big pressure buildup = turbo seal destruction = where did my oil go? oh its everywhere, look at the pretty fire.......
we did get the engine going again after about 20-30 min, but the infamous knock knock tap tap was audible from inside the car
cheers boosted 26 for ur support....
https://www.sau.com.au/forums/topic/47145-the-final-word/#findComment-953700
yeah im pretty sure the rings are gone....but the engine did seize mid cruise due to no oil. the actuator weld came off so no wastegate = big pressure buildup = turbo seal destruction = where did my oil go? oh its everywhere' date=' look at the pretty fire.......QUOTE']
That statement isn't quite logical, with no wastegate actuator you wouldnt get any boost at all, or close to none.
https://www.sau.com.au/forums/topic/47145-the-final-word/#findComment-954757
yup can sympathise with you bud - my 25 blew thru noones fault tho ...... wasnt prepared for such an outlay of money .... really didnt expect it ..... got a personal loan then just went the forgies now hopefully i never have to worry about it again. *touches wood*
https://www.sau.com.au/forums/topic/47145-the-final-word/#findComment-956732
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
