Josh's Garage Clean Out - Injectors, Turbo, ECU and More
Hey guys. Reached a stage where I can finally clear out a bunch of stuff I've accumulated during my build. Prices listed are ONO, available for pickup from Auburn NSW 2144. Willing to ship at buyer's expense. Parts are also listed elsewhere.
Too many pictures so I've created a Google Drive link here: https://drive.google.com/drive/folders/0BxkDOGQ7as9eLTE2RDE5RDVFRm8?usp=sharing
Stock RB25DET Turbo, worked fine when pulled off for upgrade: $140
"MaxSpeedingRods" Ebay Special Turbo - Decided to go a different way. Brand new, never used. Specs on request: $250
NISTUNE Z32 ECU to suit RB25DET - removed for upgrade: $400
Stock RB25DET ECU from R33 S2 Manual: $80
Stock RB25DET S2 AFM: $50
GFB G-Force II Boost Controller - fitted for test, used something else, brand new as pictured: $240
550cc WRX STI Injectors with adapters to suit RB25: $200
370cc OEM RB25DET Injectors: $150
OEM Coil Packs suit RB25DET S2 - Working fine, selling due to upgrade to splitfires: $180
JVC KW-R500 Double Din Head Unit/Car Stereo, works fine and comes with harnesses: $60
Alpine MRX-F35 4 Channel Amp - Works fine: $150
Update:
Update:
  • 3 weeks later...
On 01/08/2017 at 7:12 PM, inmaniac said:
Update:
Yellow Jacket Coil Packs - Used for 400km: $250
Updated. Now also have a full set of YJ's to suit S2 RB25, $250 ono
  • 4 weeks later...
  • 1 month later...
"MaxSpeedingRods" Ebay Special Turbo: $200
550cc ebay jecs Injectors with adapters to suit RB25: $100
370cc OEM RB25DET Injectors: $120
OEM Coil Packs suit RB25DET S2 - Working fine, selling due to upgrade to splitfires: $120
JVC KW-R500 Double Din Head Unit/Car Stereo, works fine and comes with harnesses: $40
Update - now priced to go go go
Also got my staggered set of VOLK TE37's here:
  • 4 months later...
UPDATE:
Seriously priced to go.
"MaxSpeedingRods" Ebay Special Turbo BRAND NEW IN BOX: $150
Yellow Jacket Coil Packs - Used for 400km: $200
Stock RB25DET ECU from R33 S2 Manual: $50
OEM Coil Packs suit RB25DET S2 - Working fine, selling due to upgrade to splitfires: $100
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
