Josh's Garage Clean Out - Injectors, Turbo, ECU and More
Hey guys. Reached a stage where I can finally clear out a bunch of stuff I've accumulated during my build. Prices listed are ONO, available for pickup from Auburn NSW 2144. Willing to ship at buyer's expense. Parts are also listed elsewhere.
Too many pictures so I've created a Google Drive link here: https://drive.google.com/drive/folders/0BxkDOGQ7as9eLTE2RDE5RDVFRm8?usp=sharing
Stock RB25DET Turbo, worked fine when pulled off for upgrade: $140
"MaxSpeedingRods" Ebay Special Turbo - Decided to go a different way. Brand new, never used. Specs on request: $250
NISTUNE Z32 ECU to suit RB25DET - removed for upgrade: $400
Stock RB25DET ECU from R33 S2 Manual: $80
Stock RB25DET S2 AFM: $50
GFB G-Force II Boost Controller - fitted for test, used something else, brand new as pictured: $240
550cc WRX STI Injectors with adapters to suit RB25: $200
370cc OEM RB25DET Injectors: $150
OEM Coil Packs suit RB25DET S2 - Working fine, selling due to upgrade to splitfires: $180
JVC KW-R500 Double Din Head Unit/Car Stereo, works fine and comes with harnesses: $60
Alpine MRX-F35 4 Channel Amp - Works fine: $150
Update:
Update:
  • 3 weeks later...
On 01/08/2017 at 7:12 PM, inmaniac said:
Update:
Yellow Jacket Coil Packs - Used for 400km: $250
Updated. Now also have a full set of YJ's to suit S2 RB25, $250 ono
  • 4 weeks later...
  • 1 month later...
"MaxSpeedingRods" Ebay Special Turbo: $200
550cc ebay jecs Injectors with adapters to suit RB25: $100
370cc OEM RB25DET Injectors: $120
OEM Coil Packs suit RB25DET S2 - Working fine, selling due to upgrade to splitfires: $120
JVC KW-R500 Double Din Head Unit/Car Stereo, works fine and comes with harnesses: $40
Update - now priced to go go go
Also got my staggered set of VOLK TE37's here:
  • 4 months later...
UPDATE:
Seriously priced to go.
"MaxSpeedingRods" Ebay Special Turbo BRAND NEW IN BOX: $150
Yellow Jacket Coil Packs - Used for 400km: $200
Stock RB25DET ECU from R33 S2 Manual: $50
OEM Coil Packs suit RB25DET S2 - Working fine, selling due to upgrade to splitfires: $100
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
