No problems running "moderate" upgraded terbs with the std ecu. You will start to approach the limit of the std injectors and prolly also be near the limit of the afms.
Check the a/f ratios on a dyno, however, to ensure all is OK with fuel supply however.
gtrken on these forums has prolly done this a squillion times before and could offer more advice.
fyi,
a friend of mine ran the N1s on his RB26 with the standard and everything was fine, although he only ran 12psi, and it went quite hard.
i believe he is selling these turbos atm, so if you're interested PM me and i'll pass his details onto you.
lazza ,
dont bother with the stock ecu , they will run fine but very rich , got them in my gtr .
get a pfc get it tuned and you will have an 11 second car just with turbs , pfc and a good exhaust . thats all i've got and i ran 11.7 @120mph at wsid . when i had the stock ecu i had nowhere near the power that i have now and i was getting 300 - 350 km per tank , after pfc and a tune i'm getting 450 -500 k per tank and i can loose traction on a dry road in second gear when it comes on boost on the stock 17 X9 's with 245x45 tyres
Does it matter?
Oh yes, the R32 ECU can be tuned in real time on the dyno fairly easily. You get pretty goods results from a mild R32 GTR by tuning the standard ECU. This is not so easy with the R33 ECU, if fact I reckon it is so time consuming (costly) that it is cheaper to buy a PFC. :)
Oh yes, the R32 ECU can be tuned in real time on the dyno fairly easily.  You get pretty goods results from a mild R32 GTR by tuning the standard ECU.  This is not so easy with the R33 ECU, if fact I reckon it is so time consuming (costly) that it is cheaper to buy a PFC. :D
Or just use the R32 ECU in the R33 - my old Mines ECU did the rounds of Perth including an R33.
The ECU is acutally a lesser known jap brand and i cant find any info on it at all.
Its a Power Selection ECU???
I assume that is is not tunable so I will probably look at a PFC, but considering I am about to fork out for turbs I may pospone the PFC until the cash flow improves! Hence my question regarding whether the N1s will be ok with the ECU thats in the car at the moment.
The car is an R33 GTS-T with an RB26DETT transplant, Im not sure whether it is an R32 or an R33 engine??
Thanks for the responses guys.
Lawrence
You are probably right - my old Mines ECU had a big dob of epoxy resin over the eeprom chip. Other brands probably follow suit.
As Steve-SST says above, I am selling my GTR PFC/HC/Boost Kit at a very cheap price in order to help pay for my rebuild. PM me if you are interested.
Gav
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
