Hi guys,
I'm having an issue on heavy acceleration, notably in second gear. The car loses traction and the rear kicks out, causing the car to snake quite dangerously.
I'm assuming the problem is the LSD is worn because it feels as though only one wheel is losing traction therefore causing the car to swerve.
Checked suspension for play and everything seems fine, and booking an alignment in this weekend.
Car has 258rwkw and im running federal rsr in 235.
Any suggestions?
https://www.sau.com.au/forums/topic/471482-worn-r33-gtst-stock-lsd-symptoms/
Does it leave 2 black lines on the road or 1. This will tell you if your LSD is working or not. Mine works fine until the oil gets real hot after multiple laps on circuit. On the street it's fine. Your car wouldn't be kicking out of it was single spinning. My 2c
  • Like 1
There is a widely held belief that the V in VLSD is for Viscous - I actually believed this for a time. I now know that it stands for Virtual - it isn't a real LSD, just a pretend one. When the going gets tough it isn't much better than an open diff.
As Molly would say, do yourself a favour and get a real LSD. You'll wonder how you survived without it.
1 line, no good. The kicking out will be when the second wheel does actually get some drive and will be making it unpredictable. I've also been thinking about a 1.5 way but my vlsd is still doing ok,paints nice 11's on the asphalt. Eventually I will make the switch though. #Nismolife
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
