small oil leak
Sup guys,
I got a small leak happening. I never realised until my brother called me up and said he didn't want me to park my GTR in his garage anymore :(
 It's been parked for 1 month in my bros garage and there's maybe like 15drops of oil. So I'm guessing it drops a bit when warm and then stops. I parked it in the driveway with cardboard under the car. If i guess with where the oil lands (the drops are slightly spread out, maybe like 1 inch or 2 apart on the carboard) it seems to be right under the pulleycover (big cover with the big rb26 writting on it in front of the engine).
 I checked under the hood and everything looks nice and tidy. Under the car there isn't much stuff this far up front, maybe the front diff?
I' m getting it tuned this week and mentionned it to the tuner. He's going to have a look at it.
What can it possibly be? I checked the engine oil and everything is fine there as well.
https://www.sau.com.au/forums/topic/471489-small-oil-leak/
steering rack, check it out where the metal fittings are. Nibbing them up helps for a little while but the brass washers cause issues.
Providing you have checked all the usual. Sump plug/washer, oil filter, tappet cover gaskets, dip stick and pipe where it joins the eng, catch can & hoses, general lines & intake pipe, power steering hoses.
Edited by Anonymouse
update
  • Like 1
https://www.sau.com.au/forums/topic/471489-small-oil-leak/#findComment-7842753
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
