Christian & co,
Is it possible to get the rules for selling items changed so that people have to upload a pic of their item to be able to sell it?
Seems like in every thread, the first thing people are asking is if they have a pic of the item... Makes sense to me that this should be mandatory...
Kyran.
https://www.sau.com.au/forums/topic/47149-pix-in-for-sale-section/
we were discussing organising a gallery section where you could upload photos, and maybe a tutorial showing you how. I'll see if I can work out a way of modifying the forums so that when you hit submit in the for sale section it asks you for filenames of photos to add to your post.
But yeah we have thought about this, hopefully a solution is upcoming.
yeah.. people are a little stupid. Picture sells an item a heap quicker and saves a lot of hassles. Ranging from a whole car to some little widget.
And its not hard to upload one either or host it somewhere and just link it.. but people are often n00bs and don't even know how to do that (or too lazy to learn).
But you have to give people a bit of a break as not everybody does have a digital camera or is as l33t as us all :) Half the time i feel like emailing the seller myself and offering to host the pix to take the stupid load and "pix please" pointless replies.
Its a good idea, but as predator says so well .....
Its hard enough trying to get people to follow the simple rules we have now (see a few of those people posting in this thread even!) so it would be almost impossible to try and get everyone to post pics.
I can see where you're coming from, but I would suggest that it would involve some changing of code, and some process (manual or automatic) that might be more trouble than it's worth. Far easier to just enforce a 'you must have a pic of the item' policy.
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
