The answer is a bit rubbery, will depend a little on how big/small spec your turbine and exhaust system is.  The original springs aren't that heavy, and if they've seen a bit of work it's probably time to replace/upgrade.
Setups will vary, and some will experience float earlier than others if the springs in that car are on the softer end of production tolerances or otherwise tired.
If I was looking to run up over 20psi, springs would be on the shopping list.
  • Like 1
Might be irrelevant but with stock cams and a Hypergear SS2 EWG I was able to squeeze about 25psi into the motor without any valve float on the stock springs. Motor lasted about 1 year of track abuse before it went bang lol.
  • Like 1
It really is a how long is a piece of string questions, basically it all comes down to a lot of things including cams, how far you want to rev it, wear on the springs or even the old was it built on a Wednesday or is it a Friday afternoon special
  • Like 2
OK, thank you ...
I'm usually not revving the engine highly , it rarely sees 6500 rpm. The limiter is set to 7000 rpm.
The engine has 70k km on the odo, and poncams installed.
I'll take your advice and will run 20PSI for the time being, other than on a dyno how can you tell you get into valve float territory?
So you are getting float, or don't know and are just chasing info?
Probably a bit hard to contemplate playing with the tune without at least giving it a squirt on the rollers to validate what's going on.  You can achieve plenty with road tuning, but an hour of dyno time isn't that expensive and will tell you heaps.
  • Like 1
I was trying to get some information since got a new turbo capable of 24PSI@ 6500rpm which is a big step from the 15PSI of the old turbo.
While being on a roller I found that the power curve went through some strange 'ditches' and I was wondering if that might be due to valve float.
Valve float was not of any concern to me before simply because my old turbo was running less boost.
I'll dial in 20PSI and run more timing to get a good baseline, from there I can work it up should I feel the need.
On a serious note however http://www.hypergearturbos.com/index.php?route=product/product&product_id=57
Scroll down. Click dyno results, scroll down and read special consideration for rb25 and it has some info on this for you
Good stuff. Sorry for hi-jacking the thread a bit but can you guys recommend valve springs? Heard supertech are good, are singles enough or should you get dual springs while at it? Retainers aswell or are springs enough?
In my case running rb30 (not forged) so revving only 6800 atm. Looking for ~500-550 hp, now at 440hp and 23psi (holset he351) with suspected leaking standard bov
    • Nope, but they are definitely one of the default choices. Well established.
    • Has anyone used > https://performancecoating.com.au/
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
