I've been wondering guys, how much would mt GTR be worth in australia?
123000km on the clock, decent paint, paint looks nice but not the best quality, the entire interior is there but both seats have a small rip on the bolsters nearest to the door and it shows its age (wear and tear on the leather parts) Full adjustable coilovers, 18'rims, nicely rolled fenders (looks really good). Rest is 100% stock.
How is this relevant to the topic? Make a new thread. Also, look at other cars that are selling that are close to your spec. Shouldn't be hard to see what the market is paying for them.
More than you can afford pal.
R32 GTR.
  • Like 2
R32 GTR.
Well yeah, since I alteady spend my cash buying one :P
Bruh, we've been talking bout moosepower and canadian domestic market air before and you think that was on topic?
Things aside, I'm being real impatient getting my sky back so I'm rummaging through the forums to keep busy when I'm not working.
  • Like 2
$15-$25k
Maybe more with the "external BOV" ;)
Well f**k.
I called the tuner this morning to have some more news. His dyno is ready and everything is set for a dyno run... Except the GTR.
The oil pressure is low af. So low that the oil pressure light sometime comes on when it's idling. He doesn't want to dyno it in that state.
He's currently investigating to what causes said issue. I'm afraid I have a messed up oil pump and will need to get it replaced. Could possibly explain the oil leak I have. Should have some more news coming.
6 hours ago, drunken0elf said:
Well f**k.
Got a bit of better news.
He's quite busy so only had time to rapidly check the car. The odds that it's the oil pump are low. The oil leak is probably from the powersteering pump or something connected to it (gasket,seal or whatever) and the crappy oil pressure is probably due to the old ass sensors acting up.
Waiting for him to get a more in depth look. Guess it's gonna sit there another 3 weeks lol. :P
Oh well. Much rather not drive my car for 2 months then risk blowing up the engine because of a faulty oil pump.
Edited by drunken0elf
  • Like 1
the oil pressure sender is known to go bad, luckily it is an inexpensive fix, same unit as 300ZX and should be readily available at local auto parts store.  so try that first before jumping to the conclusion that oil pump is bad.
1 hour ago, GTSBoy said:
Yes....but the oil pressure switch is a separate thing, yes?.  So for them both to indicate low pressure is not the best news.
Exactly why he wants to investigate. He's quite good with electronics, so I'm guessing he's going to test the voltage and wiring.
57 minutes ago, Hadouken said:
Put a oil pressure gauge on it and know for certain
Probably will be part of the solution, but it's the darn oil pressure switch that bothers. Does it switch on because it's based of the pressure reading from the other sensor or does it have a reading of it's own?
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
