Suspension mods for an R34 GTT
Hey Guys,
What suspension mods would you recommend doing on an R34 GTT to improve the handling, currently the only suspension mods i have are some BC coilovers.
The car is my daily, it doesnt see any track use, just some spirited driving outside town around the windy roads where i live.
https://www.sau.com.au/forums/topic/471504-suspension-mods-for-an-r34-gtt/
Tein or similar castor rods with pillow ball front joints.  Far and away the best thing you can do to the front end.
Poly upper arm bushes are a good thing at the front.  Get them with adjustability to be able to tweak the camber.
At the rear it is a tougher thing.  There is no point in only doing a little bit.  Once you consider changing one arm, it becomes an all or nothing sort of thing.  But minimally, bin the HICAS and put in a proper eliminator kit.  With a good alignment.
After that, you're looking at the next "minimal" thing being to put adjustable poly bushes in all the upper arms.
After that....it's fully adjustable arms up top, with rubber outer bushes or even pillowballs if you give no fark for police attention and NVH.  But that it overkill for a streeter.
  • Like 1
The worst thing you can do is put pillow ball front joints in the car.  It will change it so that every bump you go over will be amplified through the chassis and annoy the hell out of you.  So don't do it.  Other radius arms are fine without such joints also - nothing wrong with bushes.
If you want to do something get good spring rates and good dampers and match them to sway bars.  Good alignment (including ride height), low unsprung weight and no HICAS is about as good as you can hope for.
As was said in the first reply - good tyres make a huge difference.
I still maintain that on front castor rods you can barely tell that they're there (from an NVH perspective) but that they work a million times better than even stiff urethane bushes.
I agree that they make life hard anywhere else.
Bin the BC junk and put something that's half decent in there.
Bushes! The more of these you change, the better. It's definitely a case of "oh wow, I didn't realise how bad it was" until you start replacing them OR changing arms that have new bushes in them. It is basically a 20 year old car. They're going to be flogged! Alloy rear cradle collars is a great place to start. The difference just by doing that is huge!
* Every arm on my own car is Pillow Ball and it's nothing like you guys are describing. You would hardly know!
  • Like 1
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
    • I get into huffs with people when I suggest the MX5 looks so much better as a coupe than it does as convertible. Pretty sure I don't prefer the convertible version of anything. Good job on the hardtop! The next buyer will appreciate.
    • IMO wrap does have its uses, but like you said, quality wrap, and professional installation, would probably cost want a quality paint job does, but, the paint, if maintained, is basically for life, and much easier to touch up if required  In other news: it's pissing down here, with thunder, lightning and only some small hail "at this stage", luckily all "my" cars are undercover  I've also been contacted by a guy in Newcastle about the SS, he said he will come down next weekend for a look, we'll see how that transpires I guess 🫰
