So car started fine yesterday, didn't drive it today. Started it up to go throw some fuel in and was welcomed with this banging noise like someone had thrown a brick into a dryer.
Any suggestions from the video attachment??
Engine Noise.mp4
Edited by BstewyR33
attachement didnt attach
https://www.sau.com.au/forums/topic/471538-bad-engine-noise/
sorry mate but you've spun a bearing, probably big end.  If you give it a little rev does it get worse (best way to confirm if it is big end vs main, but either way the bottom end needs fixing)
what does the oil pressure gauge and/or light say when it's running? Do you still have any oil pressure? What were you doing last time it didn't make the noise?
also, if you intend to rebuild it rather than replace it, every single revolution does more damage and increases cost to rebuild...
if you are feeling optimistic you could take all the drive belts off (water pump/fan/alternator, power steer, aircon) and start it briefly and see if the noise is still there, but the video is pretty distinctive.... :(
Awww shite... Thanks man. Can't complain for a 22 yr old engine which hasn't had any work done to it and lasted.
The noise did increase with revs, Oil pressure has remained the same - didn't see any drops in the gauge while driving, never had any lights come on to indicate otherwise. Have noticed a slight belt squeal lately on start up, not sure which belt though
Is it a costly rebuild?
Edited by BstewyR33
Added text
  • 3 weeks later...
You could ask if anyone here has a book with torque specs and how to rebuild a rb25det..
That way you can drop a new bottom end in your car and keep your old engine and slowly rebuild it yourself.
Could be fun if you into that stuff.
a bit of an update - had a mobile mechanic out to have a listen and look & he suggested it could be some dirty lifters as the noise wasn't down low on the block. Threw some nulon lifter free & tune up in and the sound went away, a band-aid solution - will have to get around to do a overhaul on the engine at some point.
Not really dodgey at all and a good cheap outcome. Seems like it was just a sticky/noisy lifter. If the problem re occurs, (probably won't if you keep the oil in good conditon) just replace the lifters or isolate the offending lifter and replace that only. I recently spoke to a bloke that had this occur and he ran some engine flush through the engine and changed the oil and 3 years later noise never returned.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
